Results 1 to 20 of 30
    Junior Member dhillyard's Avatar
    Plymouth, MI
    2002 Trans Am WS6
    Whats possible for me to run with 373rwp,371rwtq?
    Hey guys, last time i ran with 356 rwhp and i could only get a 13.14 @110mph.
    What do you think I should run now? All that is done is Mac mids, ORY, Corsa Cat-back with open dump after the y, 80mm BBK TB, SFCs, STB, SLP lid w/ k&n, short stick for the m6 with stock gears and chassis dyno tuneed to 373rwhp, 371rwtq.
    Also on the stock crappy 275 goodyear eagles
    LS1 land
    those are pretty good #s for your mods. Make sure you deflate your tires and get those 60' down. if you ran 13.1 before i would guess 12.8-12.9 now. Good luck!
    Member silverz28camaro's Avatar
    Washington MO
    sebring silver
    2000 z28
    my car is 13.08 @107 with factory wheels 1.988 60 havent dynoed but probably around 316 being stock besides slp cai, and magnaflow 2.73
    get traction and see your 12.4
    Plymouth, MI
    2002 Trans Am WS6
    well, i have my street tires, how much psi should i run in them at the strip? Also, what is the best choice of drag radials and what size? thanks for the tips guys.
    General Mota's! stevegrizzle's Avatar
    Around Tampa , FL
    mid blue
    99 m6 z28
    i think a lot of people are having good things to say about teh m/t et streets. I personally like the nitto555r's.
    Ms
    Quote Originally Posted by stevegrizzle View Post
    I have had both and the m/t drag radials hook way better but the nittos last a lot longer so its really just a matter of what you want.
    Ms
    Quote Originally Posted by dhillyard View Post
    Oh yea you might want to invest in a 12-bolt or 9" rear end.
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    grab a panhard bar for about 100$ that will help with traction
    Junior Member JETNITRO's Avatar
    Central New Jersey
    2004-Quick Silver
    11 Second Club
    put a set of drag radials on and you might run 12.30-12.40
    Member GA Country Boy's Avatar
    Aug 2006
    Cumming, GA
    Metallic Red
    2002 Corvette Coupe
    Don't let anyone tell you that deflating radials is going to help you. Radials have hard sidewalls and are not designed to run with lower pressures like bias-belted
    slicks that have soft sidewalls and will wrinkle. Deflating radial tires causes them to cup in the center and in fact reduces the amount of tire reaching the ground and also reduces the amount of traction.
    Michael
    In GA waving from '02 C5 LS1, Z51, D1SC, 60lb injectors,RPM level 5-4L60E, 3:42, Yank 3600, QA1-12 ways, MTI long headers, high flow cats, Borlas, Wilwood, 603rwhp, 542rwtq.(DynoJet 248-C) 10.89@127.57 on street tires, Race Weight 3,640 lbs
    Around Tampa , FL
    mid blue
    99 m6 z28
    I agree with in principal, however, running drag radials at 30 psi will result in less traction than at 22-24 psi. IMHO running below 20 psi will result in less traction and so on. There is definately a point where you are at the optimum level of traction and it is not at the 30 psi level.
    Aug 2006
    Cumming, GA
    Metallic Red
    2002 Corvette Coupe
    I thought we were talking about "Goodyear Eagles" that the ORIGINAL poster is running. BUT if you're NOW talking about DRAG RADIALS I would offer this info from BFG:
    "It is also important to remember that the Drag Radial operates most efficiently on the strip at COLD inflation pressures of between 15psi and 20psi (in no case should below 12psi be used). And after the racing is done for the day, it is essential that Drag Radials be reinflated to normal highway operating pressures in order to safely bring the driver and trophy back home. Running any tire at relatively low inflation pressure for a given load reduces the tire's speed capability by causing it to stretch more and operate at a high deflection (more radial bulge). The Drag Radial is built to withstand brief "bursts" of high speed while inflated at low pressure (such as would be experienced on a quick car in the quarter-mile), but no tire can be expected to survive for a long time at high speed while operating at high deflection."
    You DON'T want to ever run regular radials at 15-20psi!!!
    Around Tampa , FL
    mid blue
    99 m6 z28
    my mistake, i thought we were talking about drag radials. we are in agreement.
    Pittsburgh
    You got a dyno sheet to prove those numbers. Im having a real hard time believing 370+ HP with mids, ORY and lid.
    02 TA A4
    408ci - 244/250/612/622 | PRC 237 heads | FTRA |100mm lid | FAST92/92 | Kooks 1 7/8 | Hooker CB | DMH Cutout | built trans | Yank4000 | 412 motorsports tuned | stock rear:judge:
    08 TBSS - Borla CB
    Around Tampa , FL
    mid blue
    99 m6 z28
    he has a 80mm TB and a tune too.
    Pittsburgh
    Still aint seein 370+. Im gonna call until I see proof.
    If you look in my sig at my mods and a tune from Mikey at Rapid Motorsports I was just under 350.
    Oh and I ran 12.46@107.9 with a 1.68 60ft on BFG DRs.
    Evr sena bdgr killa snak? Roastem's Avatar
    Research Triangle Park, NC
    '99 Z28 M6
    I needed a cam to hit those numbers.
    Good traction should net you low 12's.
    Pittsburgh
    Most do. Thats why I call BS. Havent heard back from him.
    Around Tampa , FL
    mid blue
    99 m6 z28
    Quote Originally Posted by onyx_rock View Post
    I'm trapping higher than that with just LT's and an ORY and Cutout, on 93 oct. not near that on the 60's tho....
    IMPORT KILLER PEWTER Z's Avatar
    Pasadena, MD
    PEWTER
    1999 Z28 CAMARO
    I have to agree. My dyne tune was netted 300 RWHP, with my converter unlocked, and I've managed a 12.56 @ 108 on BFG DR's myself.
    99 Z28, A4, 3.73, Jet Hot LTs and ORY, Hooker Catback w/cutout, Phoenix Pro 3500 2.5 STR converter
    LS1 Motorsports Lid, Dyno tuned by Bret @ Fbodycentral
    12.36@ 109.64 MPH 1/4 mile, 7.86 @ 86.95 MPH 1/8 mile
    1.69 best 60', .511 RT
  1. Whats up from Tx.
    By yanoZ28 in forum New Member Introductions
    Last Post: 10-27-2009, 05:54 PM
  2. whats up everyone!!!
    By enyaw619 in forum New Member Introductions
    Last Post: 09-24-2009, 08:54 AM
  3. whats up
    By fatalvision in forum New Member Introductions
    Last Post: 01-23-2008, 07:36 PM
  4. WHats up!!
    By T-SPOON in forum New Member Introductions
    Last Post: 10-21-2006, 02:35 AM
  5. whats up
    By antlop in forum New Member Introductions
    Last Post: 10-19-2006, 04:06 PM
