    Mike The Guz's Avatar
    Lawndale, CA
    Artic White
    2002 Camaro SS
    2002 Black Corvette Paint Correction + Optimum Gloss Coat
    The owner of this 2002 Corvette is one of my many uncles (my mom's baby bro). A brief background on the car. He is the second owner and he has had it for roughly 10+ years. He had the car repainted due to clear coat failure on the rear quarters. The high UV index here in Southern California will do that along with not enough care.
    Tools and products used:
    Wash:
    Detailer's Pro Xtreme Foam (Now McKee's 37)
    Griot's Garage Fast Correcting Prep Mitt
    Car Pro IronX
    Wheels:
    Griot's Garage Heavy Duty Wheel Cleaner
    Detailer's Pro Xtreme Foam in a bucket for my brushes
    Wheel Woolies
    Lug Nut Brush
    Mothers Wheel Brush
    Rupes Keramik Polish on the Rupes nano
    Car Pro Eraser
    Car Pro DLUX
    Tires:
    Meguiar's D108 Super Degreaser at 4:1
    Detailer's Pro Tire Rejuvenator (Now McKee's 37)
    Tuf Shine Tire Brush
    Detailer's Pro Tire Coating (2 coats) - Now McKee's
    Wheel wells:
    Meguiar's D103 APC+ with a brush
    Meguiar's D160 All Season Dressing
    Glass:
    Clay Magic Clay Bar
    Meguiar's D120 (used to clean the glass and clay lube)
    Meguiar's M101
    Optimum Paint Prep
    Optimum Opti-Glass
    Optimum Opti-Glass Clean & Protect
    Paint Correction:
    Rupes LHR15 Mark II
    Rupes Mini
    Rupes Nano
    Griot's Garage Boss Microfiber Cutting pad
    Meguiar's D300 Microfiber Correction Compound
    Rupes Yellow Foam pad
    Rupes Keramik Fine Gel Polish
    Optimum Paint Prep
    Optimum Gloss Coat (2 coats)
    Optimum Opti-Seal (used to protect gloss coat during the curing time)
    Trim:
    Meguiar's D103 APC+
    IPA
    Solution Finish
    Optimum Paint Prep
    Optimum Gloss Coat
    Exhaust Tips:
    Meguiar's Fine Cut Metal Polish
    Car Pro Eraser
    Car Pro DLUX
    Interior:
    Meguiar's Quik Interior Detailer
    303 Automotive Protectant
    Meguiar's D181 Leather Cleaner
    Car Pro Cquartz Leather Coating
    Optimum No Rinse as glass cleaner
    Engine Bay:
    Meguiar's D103 APC+
    Blackfire All In One
    Tailights:
    Rupes Mini
    Rupes Zephir
    Rupes 4" Blue pad
    Optimum Paint prep
    Optimum Opti-Lens
    Headlights:
    Optimum Paint Prep
    Optimum Opti-Lens
    First thing was washing the wheels. Wheel Cleaner doing it's thing on the passenger side wheel.
    Front driver side wheel
    Before
    After
    My dedicated wheel bucket afterwards just to give an idea of how dirty they were
    Once the wheels and tires were cleaned it was time to wash the car. As always I start off using the aggressive wash method courtesy of Mike Phillips (The Aggressive Approach to Washing a Car)
    This completely stripped whatever was on the paint. The car was dried to inspect the paint in the sun. This is what we saw.
    We pulled the car into the garage and the first thing that we attacked was the interior.
    All leather was cleaned with Meguiar's D181 leather cleaner followed up with a damp microfiber towel to prep the leather surface for Car Pro Cquartz Leather Coating.
    Before (this is how the engine bay looked like when it arrived). It's been to Arizona a few times so it needed a good cleaning.
    While I was working on the interior my brother took it upon himself to dress up the engine bay. I forgot to mention that he cleaned the engine bay with APC and some brushes while I was cleaning the wheels.
    After it was pulled into the garage after washing and deconing the paint the engine bay was dressed with Blackfire All In One Trim and Tire Protectant
    We called it a day after that.
    The next day I began polishing the glass. My uncle ran water over the car and left it like that. It created some pretty bad water spots on the glass, taillights and paint. DP Glass Restorer Polish on a cutting pad did nothing as did clay. I had to go with Meguiar's M101 on a cutting pad using my Meguiar's MT300 to remove them. It was on all the glass.
    I got most of it out.
    During the work week I would do a panel here an there after I got home from work.
    I proceeded with a test spot using M205 and it removed most of the defects but the paint would require a more aggressive polish to remove the deep defects. I ended up compounding the car with Meguiar's D300 on Griot's Garage Boss Microfiber Cutting pads. This was giving me the correction I wanted. It also is a low dusting compound at least for me.
    Here's the rear quarter panel area.
    Before
    Clarity restored.
    Lawndale, CA
    Artic White
    2002 Camaro SS
    Roof
    After
    Edge work
    While I was wrapping up compounding the paint, I took the next project on which was his taillights. There were some water spots on them as well. I took each one off and used my Rupes Mini to compound them out.
    Before
    After. No the lens is not broken. That is a reflection. These were coated with Opti-Lens later one while I was coating the paint
    Once I figured out what worked to finish out the paint, I followed up with blowing out the paint and crevices with compressed air to remove as much of the compound and polsihing dust. I then rinseless washed with ONR to remove the remaining compound and polish dust. I preped the surface with a couple wipedowns of Optimum Paint Prep. The paint was coated with a double coat of Gloss Coat (1 hour apart) followed by 1 coat of opti-seal (1 hour from the last coat of Gloss coat) to protect Gloss Coat during the cure time of a week.
    The humidity was higher than normal which caused Gloss Coat to flash quicker.
    I tried something different this time with Gloss Coat. I typically use the Car Pro block and suede applicator. This time around I used the blue foam applicator that comes with Gloss Coat. I found that to be even easier than the block and suede applicator. I used the same amount of product with the foam applicator that I do with the block and suede applicator. To those that say the foam applicator absorbs a lot of product I would have to disagree.
    Gloss Coat flashing
    Looking good after one coat
    During those wiat times between coats, the face of the wheels were polished with Rupes Keramik on a Rupes Nano and coated with Car Pro DlUX following a wipedown with Eraser.
    The tips of the Borla cat back were polished with Meuiar's Fine Cut Metal Polish and prepped with Car Pro Eraser. They were also coated with DLUX
    Here are some final photos to show off the end result. I had some dust on the camera lens.
    Lawndale, CA
    Artic White
    2002 Camaro SS
    New plates
    2 coats of DP Tire Coating
    Beautiful defect free paint
    The paint came a long way from this
    To this
    The transformation is night and day.
    Lawndale, CA
    Artic White
    2002 Camaro SS
    Walk around video
    2002 Artic White SS 35th Wheels|Full Hotchkis Suspension|Koni SA|Magnaflow CME|SLP lid|www.fquick.com/The_Guz
    Feb 2015
    Harrisburg, PA
    1995 Firehawk
    That is really nice. Nothing like a shiny black car.
    Senior Member Naaman's Avatar
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    Great job!
    Lid, Throttle Body, LS6 Intake, Heads, Cam, Magnaflow, LS7 Clutch, SFCs, STB, Panhard Bar, Strano Springs, Hollow Sway Bars, Poly/Roto LCAs, Konis, MGW Shifter
    Member hardtrailz's Avatar
    Jul 2016
    SE IN
    Blue Green Chameleon
    2001 Trans Am Vert
    Wish i had that patience.
    Looks good
    2001 Trans Am Vert
    Apr 2010
    Alabama
    Black/ Silver
    98 TA WS6/ 01 C5 Corvette
    Gives me hope to fix my swirl black paint on my TA. Glad the paint on my Vette is defect free.
    Sent from my HTC6535LVW using Tapatalk
    1998 Trans Am WS6 - Phantom
    421 LQ9 14.8:1 on E85 Build/
    Excellent work!
    Custom Car Emblems
    from third_shift|studios
    jaison tortorea
    Damn nice work!
    024mula 024mula's Avatar
    Dec 2010
    Ohio
    '02 Firebird Formula
    Nice work!
    2002 Firebird Formula - 5.7 Liter - "Last of the Breed"
    Lawndale, CA
    Artic White
    2002 Camaro SS
    Quote Originally Posted by taman76 View Post
    Thanks
    Quote Originally Posted by Naaman View Post
    Great job!
    Thanks
    Quote Originally Posted by hardtrailz View Post
    Looks good
    Thanks. Just good lol.
    Quote Originally Posted by 98TransAmWs-6 View Post
    Black is a full time job. Glad I don't own a black car of any sort as much as they look good.
    Excellent work!
    Thanks
    Damn nice work!
    Thanks
    Nice work!
    Thanks
  1. 2010 Camaro Paint Correction+Optimum Gloss Coat(New Formula)
    By The Guz in forum Showcar and Detailing
    Last Post: 10-28-2016, 10:58 PM
  2. paint correction/detail black paint
    By 98maro in forum Showcar and Detailing
    Last Post: 08-24-2013, 03:02 PM
  3. Question: Leave paint semi gloss black or clear it?
    By 2001camaroSS in forum Appearance Section
    Last Post: 04-03-2010, 09:27 PM
  4. Berger Panel. Gloss Black or Flat Black
    By Z28boy2000 in forum Showcar and Detailing
    Last Post: 05-27-2009, 10:38 AM
  5. Anyone paint the stock grill gloss black?
    By Maro99 in forum Appearance Section
    Last Post: 07-28-2006, 10:04 PM
