Thread: SLP Subframe Connectors
06-26-2014, 10:57 AM #1
- May 2013
- Nashville, TN
Black / White- '00 T/A M6/'19 Hemi Truck
Found a pair of SLP 3point bolt in's for $200...cant beat the price. I've heard they dont play nice with some of the ORY's that are out there and can have some clearance issues. My car isnt lowered so im not worried about ground clearance, but the y pipe issue worries me a little...Any of you guys running these?
06-27-2014, 02:23 AM #2
UMI here. You may be able to check SLP's website for fitment info.
06-27-2014, 05:11 AM #3
- Jun 2011
- Branchville, NJ
My SS had the SLP connectors already installed when I bought the car. It doesn't seem that any extreme modifications were made and the fit well and I have no ride height issues.
06-28-2014, 03:08 AM #4
SLP (like most of their stuff) suck. Go get a set from Midwest Chassis. Less than $200....10x better.
06-28-2014, 10:58 PM #5
slp you will find as you read the older post sucks and you couldn't pay most guys to put most of there part on a car. but you may get lucky some guys have good luck with there stuff. (i am not one) so i am a umi fan but to each there own
06-29-2014, 05:38 PM #6
Easy answer is that if it fits and the clearances are good, then any 3 point SFC is going to improve how the car feels.
07-01-2014, 09:25 AM #7
- Aug 2001
- San Diego, CA
383 w/Meth & ProCharger- 2001 Camaro Z28
SLP 3 point is good. This was one of the first mods I ever got for my Camaro. It pre-existed UMI so there was no choice. But having a 3 point subframe connector is excellent to hold the car together in corners. Over the years I've obviously lowered the Camaro and have Kook's long tubes and catted y-pipe. The car sits low for sure but the only thing that scrapes the ground (when I'm not being careful) is the T-Arm tunnel mount. It's beefy.
Photos
See, the car sits low.
Shot of the tunnel brace area
Drivers side showing subframe connector
Last edited by ntimid8r; 07-01-2014 at 09:39 AM. Reason: fixed/changed the pictures
07-01-2014, 10:54 AM #8
I had 3-point SLP's on my first Camaro. I loved them. Fit great no clearance issues. If I remember right, the stock exhaust was lower than the sfc. And I liked having a flat surface to put a jack on. I would normally pull up on a board or two. Then put a small 2x4 block on my jack (because I have a cheap jack that doesn't have a good head) and I could put the jack anywhere down the side.
If I had to come up with a negative issue, I would say they are heavy.
When I totaled the car out I hit a tree on the driver's side and went up on a stump. Busted the oil pan, steering rack, and bent up the k-member. But the car and the slp sfc were still straight.Last edited by blackcar; 07-01-2014 at 10:57 AM.
07-01-2014, 10:56 AM #9
- May 2013
- Nashville, TN
thanks for the info guys!
Question: Umi Subframe connectors
By davidz28 in forum Suspension and HandlingReplies: 4Last Post: 05-15-2010, 08:45 AM -
subframe connectors???!!!
By dadowd in forum ConvertibleReplies: 16Last Post: 05-12-2010, 07:25 PM -
subframe connectors
By Scanlamp in forum Rocky Mountain MembersReplies: 16Last Post: 06-20-2007, 07:25 PM -
i need help with subframe connectors
By 15T01Z28 in forum Suspension and HandlingReplies: 6Last Post: 06-12-2007, 03:25 AM -
Looking for subframe connectors....
By clg82 in forum Parts Wanted / TradeReplies: 2Last Post: 06-06-2007, 06:40 PM
