Results 1 to 18 of 18
    - = LR = - grandkodiak's Avatar
    x
    Tech Service Bulletin?
    Can anyone help me find a copy of the tech bulletin on a 1996 trans am about the drive shaft vibrations? i remember seeing it online about ayear ago but i cant find it anymore.
    NC
    Just happen to have it laying around. Wont do you much good anymore though
    The cheapest way to go is to buy a used aluminium one from a LS1.
    I have seen them in the for sale section here and on LS1Tech for as little as $50!
    Just buy new u-joints and maybe get it balanced and you are ready to go.
    x
    How big of an operation is it, something that I can do or does it need to be lifted?
    12.36@109 Red on Red WS6's Avatar
    Tulsa OK
    1996 Trans Am
    Mine vibrates pretty good at around 100+ MPH Could the steel drive shaft just be rebalanced?
    Member jasonisdn's Avatar
    nc
    96 ss
    Quote Originally Posted by grandkodiak View Post
    jack it up in the rear. undo 4 nuts on the straps that hold it in place. you might have to pry the drive shaft out , if its stuck. then lube the outside of the new yoke and gently slide it in the tail housing of the tranny . after that bolt it back up to the rearend and your done. buy new straps , try not to use the factory ones. they have been on there so long, its just a good idea to replace them.
    nc
    96 ss
    Quote Originally Posted by Red on Red WS6 View Post
    yes, if you want a shaft you never goning to have to worry about go here
    http://www.dennysdriveshaft.com/ when they put a phrase like this on it.
    IF YOU EVER TWIST THIS TUBING OR BREAK OUR WELDS...WE WILL REPLACE THE ENTIRE DRIVESHAFT FOR FREE.
    it just makes ya feel better
    NC
    Yeah, denny's is the shit. Thats what I run now
    Member koolaid_kid's Avatar
    Indianapolis
    Arrest Me Red
    1997 Formula
    I run the Spohn extreme duty driveshaft. I've only tested it to 140 (ran out of road and nerve, although not necessarily in that order), but it didn't vibrate. Just an alternative.
    Ricekiller z28punk's Avatar
    Maple Grove, MN
    2002 Camaro Z28
    yea u can have it rebalanced. it does help a lot but doesnt always fix the vibration completely
    Member dkishton1486's Avatar
    Ohio
    1995 Z28
    If you would still like to know if your car has an open bulliten or recall PM me with your vin
    Buffalo
    I agree. Avoid dealers at all cost. Chevey dealers will jack you any chance they get. If they give you the drive shaft for free, they'll charge you $50 for test driving it. haha oh ya, plus tax.
    The next car I buy definately ain't going to be a GM or Ford. Lexus, Honda or Acura possibly. Unless I get a vette, but even then it won't be new. (God willing of course)
    Ohio
    1995 Z28
    The GM dealer will NOT charge you if its uner a service bulliten/recall no matter what
    x
    Even though its almost 11 years old now and I'm not the first owner?
    Maple Grove, MN
    2002 Camaro Z28
    if its a recall, then yes, No charge. bulletins are a different story.
    Ohio
    1995 Z28
    doesnt matter how old the car is and you can be the 500th owner as long as the recall hasent be performed on the car its still open to do a free check call your local GM dealer and give them either your full VIN or the last 8 of your VIN
    x
    but this isnt a recall correct?
    Back in the day GM would honour this recall and rplace the stock steel driveshaft with a 1LE if the dealer crossed all the T's and dotted all the i's.
    The last one done for free as a 'warrenty issue' was in late 1997 and that is why I posted about the best/cheapest fix is a used alum. LS1 driveshaft. I upgraded my u-joints to heavy duty ones (Lakewood I believe) and it has worked flawlessly for me.
  1. Service Bulletin: Bubbling Sail Panels
    By Sassy Cassie in forum Appearance Section
    Last Post: 10-09-2009, 06:01 PM
  2. Tech or Service Manual
    By MJ42N8SON in forum Firebird / WS6
    Last Post: 08-17-2009, 11:05 AM
  3. Help: Tecnical service bulletin on hatch release ?
    By mdcrabbie in forum Camaro / SS
    Last Post: 02-25-2009, 05:33 PM
  4. Thanks For the Help On cat bulletin
    By cubs1 in forum General Help
    Last Post: 03-28-2008, 07:46 AM
