Results 1 to 20 of 21
08-13-2007, 08:52 AM #1
Just got off the Dyno (stock T/A)
So I just had my car Dynod before I started to Mod it. I tested it two ways one with no air filter or lid and i got 287 rwhp and 290 rwtq think that these numbers would be higher do to direct flow then I put my stock Paper filter in and stock Lid ended up with 302 Rwhp and 309 Rwtq. The test was done on a Dyno jet and like I said this is a Bone Stock 2000 T/A. Thought those numbers seemed a little high and anyone know what the diffrence in power with the Lid on ? Let me know your thoughts
08-13-2007, 01:11 PM #2
- Apr 2007
- Newport, RI
Navy Blue Metallic- '00 Formy A4
The lid and filter might smooth out the incoming air, and maybe make for a higher intake air velocity? Just a guess.
Great number, btw. M6?
08-13-2007, 01:17 PM #3
No Actually is a A-4 thats kinda why I was suprised
08-13-2007, 01:30 PM #4
- Apr 2007
- Newport, RI
08-13-2007, 01:32 PM #5
my car must be a freak, it is a 01 A4 2.73 gears with a cutout, stock everything else and I dynoed at 335ish and 365+ tq
08-13-2007, 01:36 PM #6
Wow and was that the Corrected power with the down shift taken out ? Either way thats a serious number
2000 T/A w/ minor mods
1963 Chevy II , Tubbed , Cagged , Sbc 400 Tunnel Ram Set up.
1989 Rs Former v-6 now Crate 350 (Gf Car)
08-13-2007, 01:38 PM #7
yup it was left at third and maxed their dyno at 160 MPH is why im assuming its got the 2.73 gears, and it was also on the dyno w/ my 20" rims
08-13-2007, 01:49 PM #8
Hmm Later on I got it on my camcorder , maybe ill try and make a link and put a clip on
08-14-2007, 04:00 PM #9Mods: SLP Air Lid w/ KN, Free-Mods, LS6 Manifold, Magnaflow, Headers, EFILive
Visuals: Angel eyes, rear eurolights and T/A rims
Suspension: Eibach ProKit, UMI Adj. Panhard, SFC's, LCA Relocation brakets, KYB AGX shocks
http://www.fquick.com/garages/Chevro...28/1999/23674/
08-14-2007, 06:28 PM #10
Yeah looks like you had a few small Issues though. My luck now that I'm starting to mod my car im going to lose power If it makes you feel better i was at 59% humidity and it was 72 F... Also did you have your car hook up to get the Air/Fuel reading? tried on my car but it wouldnt read right
08-15-2007, 03:53 AM #11
08-15-2007, 08:08 AM #12
Yeah i know Im not really going to lose power .. Plan on getting the car back in the mid 400's like my last bird so I will be re Dynoing in about 2 months or so to see how close I am.
08-15-2007, 10:39 AM #13
08-15-2007, 07:32 PM #14
Took the heads off getting those done at the machine shop and a matched cam that will support a bit of Nitrous. think Im going to go with mid tubes so Im getting the huge torque numbers of long tubes and not hooking, And a cat back , lid. Im going to see where that puts me and kinda go from there.
08-16-2007, 03:21 AM #15
09-11-2007, 11:26 AM #16
man what numbers, i have a 99 ss with a 2005 Ls6 (ZO6) motor swap, all stock A4 and i pulled 340rwhp, your car is freak of nature. but glad to hear hit
09-17-2007, 09:17 PM #17
- Feb 2007
- FairField, CA
RED 35TH ANIVERSARY PKG- 2002 CAMARO SS 35th LE
The reason your car had smaller numbers when their was no air filter or lid.. Was because the PCM can't read all that aif flow.. Their is too much air flowing for the mass air to get a fix reading. thats why you lose power!!! you see that when you put the lid on and the filter you gain horsepower. Because you had a steady volume of air and the mass could register it. It was a steady flow the filter not only filter's out the air but also allows a certain amount of air to flow. at a certain CFM's..
09-19-2007, 09:07 PM #18
- Jan 2007
- New Orleans Suburbs
White- '02 Formula A4
Good numbers man.
So if his A4 is a freak, is mine one too? I dynod on a dyno dynamic which people say read low and I got 295whp and 306tq. It was tested in 105* heat with humidity in the 70%-80% range. I also run 13.5s stock.
10-03-2007, 06:45 AM #19
- Jul 2007
- ohio
silver- 99 Trans Am
What is a m6? a4? how do you find out?
10-03-2007, 07:24 AM #20
What do stock LS1's dyno/run in the 1/4?
By GeeTee in forum Dyno InformationReplies: 223Last Post: 07-12-2017, 05:37 PM -
stock dyno run
By juxi in forum Dyno InformationReplies: 10Last Post: 08-26-2015, 01:21 PM -
What do stock LS2's dyno?
By Mike0202 in forum GTOReplies: 4Last Post: 04-06-2010, 02:08 PM -
By 00BadBrd in forum Dyno InformationReplies: 1Last Post: 08-13-2007, 07:25 PM -
stock lt1 dyno'd, seen it..where'd it go?
By Zapper2003 in forum LT1Replies: 10Last Post: 06-01-2007, 08:15 AM
