Thread: going faster
11-25-2020, 03:50 AM #1
- Apr 2007
- bloomfield nj
Red- 1998 trans am
going faster
I know everybody is talking about power which is great.What i wanted to know in order what i could to a 1998 trans am convertible with headers long tube full exhaust, subframe connecters , strut tower bar and slp lid.The car was tunned by frost and it runs amazing. I want to know what suspensions upgrades to make the car to handle the new power.The car is automatic with 273 gears any help would be greatly appreciated.
12-05-2020, 03:29 PM #2
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
I recommend getting all tubular suspension arms and making sure the shocks are up to snuff. I am more into handling than drag racing but I can't imagine that your setup is giving you much more than 345 rwhp and similar torque rating; and with a 2.73 rear, I don't figure anything unconventional will be in order for the car to pull OK.
SLP Air Lid/Smooth Bellows
NGK TR55 plugs
Magnaflow Cat-back
UMI Front Sway Bar
Dyno Dynamics dynoed @:
415 rwhp
12-05-2020, 03:40 PM #3
- Apr 2007
- bloomfield nj
Red- 1998 trans am
Thank you for your response
12-08-2020, 09:31 AM #4
Better springs, shocks and Lower Control Arms would help a lot. Eventually a torque arm too. That would be great for a bolt on car only to modest upgrades.
I use UMI Performance for all mine. I'm not sponsored or have received any free products from them for my devotion. I truly love their stuff and it hasn't failed me once.
Now if they see this and happen to want to send me a Christmas gift I just need the entire front end stuff to finish me off. (K member, upper and lower a arms)http://www.ls1.com/forums/f7/my-6-liter-build-174257/
00 FB Vert - Stock
12-08-2020, 09:49 AM #5
- Apr 2007
- bloomfield nj
Red- 1998 trans am
Thank you for your reply and definitely they should hook you up.
12-08-2020, 04:14 PM #6
- Sep 2010
- Bel Air, Maryland
I second UMI. I have UMI's Upper and Lower Control Arms, Rear Suspension Arms, and Panhard Rod. Only problem I had was the Panhard Rod End backing off, and coming off to scrape ground, just replaced with another one, and put some black spray paint on the threads, behind the nut, to add a smidge of resistance.
Between these parts and my Z06 wheels, I probably have shave about 40 or so pounds off of the car, with the suspension.
12-08-2020, 04:27 PM #7
- Apr 2007
- bloomfield nj
Red- 1998 trans am
Thank you so much for answering i definitely am going to put a torque arm and some really good shocks and struts.
12-09-2020, 07:34 AM #8
I used to have the STB (Shock Tower Brace) and DSL (Driveshaft Safety Loop) from UMI. I sold the STB and made a custom one to clearance my FAST 102 Intake and the DSL hung too low for the the street with a lowered car so I found one that tucks it up perfectly in the well from Midwest Chassis.
12-13-2020, 05:30 PM #9
- Aug 2007
- Corn and Soybean fields
After suspension and chassis 3.73s and a 34-3500 stall range converter
With the gears if you decide to keep the stock 10 Bolt I'd keep the 2 series carrier and 2 series 3.73s (thicker and stronger) and a girdle style diff cover
what would be faster
By purplebat66 in forum Firebird / WS6Replies: 43Last Post: 01-31-2010, 10:13 AM -
Get my car faster
By trip2016 in forum Domestics and ForeignsReplies: 8Last Post: 10-23-2007, 09:42 AM -
Getting faster
By Blown 98 Z in forum Rocky Mountain MembersReplies: 139Last Post: 09-20-2007, 05:44 PM -
Which is faster?!
By Mike's02Z28M6 in forum Western MembersReplies: 7Last Post: 06-05-2007, 08:17 PM
