Results 1 to 20 of 40
Thread: LS engine info
04-27-2007, 03:57 PM #1
The LS series is expansive ranging from 4.8 to 7.0 in steel and aluminum. The crank on all LS engines save for the 4.8 and 7.0 are the same 92mm (3.62). And if I am not mistaken all LS series also have aluminum heads.
Heres some LS info for ya.
LR4- 2003 - 4.8L 96.01 x 83 mm- Iron Block- 270-350 hp- 285-290 tq
installed in 03 Express 2500-3500 vans/ Savanna 2500-3500 vans/Silverados/Sierras/Tahoes/Yukons
LM7- 2003 - 5.3L 96.01 x 92 mm- Iron Block-285-295 hp- 325-335 tq
03 Escalades/Avalanches/Express/Savana/Silverado 1500-2500
Sierra 1500-2500/ Suburban/Yukon/Tahoe/Yukon XL
LM4- 2003 - 5.3L 96.01 x 92 mm- Aluminum Block-295-355
Trailblazer EXT/ Envoy XL/SSR
L59- 2003 - 5.3L 96.01 x 92 mm- Aluminum Block- Flex Fuel HP-?
Suburban/Yukon XL/Tahoe/Yukon/07-Avalanche/07-Sierra
Classic
LH6- 2005 - 5.3L 96.01 x 92 mm- Aluminum Block- Displacement on Demand
Trailblazer Ext/Envoy XL/Buick Ranier (No DOD)
LQ4- 1999 - 6.0 101.6 x 92 mm- Iron Block- 300-325 HP - 360-370 TQ
Express/Savanna/Silverado HD's/Sierra HD's/ 02-05 Denali
LQ9- 2002- 6.0 101.6 x 92 mm- Iron Block- 345 hp-380 tq- Flat top pistons
02-05 Cadillac trucks and Suv's/ 03-05 Silverado SS/ 04-05
Silverado and Sierra HO/ 06-07 Silverado and Sierra VortexMax
L76- 2006- 6.0 101.6 x 92 mm- displacement on demand- 355hp/365tq,
variable timing
06 Suburban/Avalanche will be available in the 08 G8
L92- 2007- 6.0 101.6 x 92 mm- Aluminum Block-Variable timing 403HP/417TQ
07 up Escalade/07 up Denali/07 up Sierra/ 07 up H2
L98 (not TPI version L98 Austrailian only L76 derivitive) 6.0 -Iron Block 362
HP/ 391 TQ
Holden Cars Commodore/Statesman/Caprice
LS1- 1997 -5.7 99 x 92 mm- Aluminum Block-305-350 hp 335-365 tq
97-04 vettes/ 97 up Fbodies/04 GTO/ Holden Cars- Statesman
Caprice/Monaro/ and all special vehicles
LS2- 2004 - 6.0 101.6mm x 92mm- Aluminum block- 400-412 hp 400-406 TQ
04-07 Holden special vehicles/05-06 Monaro/05-07 vettes/ 05-
06 GTO/05-06 SSR/06-07 Trailblazer SS/06-07 CTS-v.
LS3- 2007- 6.2L 4.06in x 3.62 in- Aluminum block- 430-436 HP 424-428 TQ
08 Vette
LS4- 2006- 5.3 96.01 x 92 mm- Aluminum block- DOD- LS6 heads- 303HP 323
TQ
06-07 Impala SS/06-07 Monte Carlo SS/05-08 Grand Prix GXP
LS6 and 7 should be known already as Z06 only motors and LS9 is just rumored at this point. But anyway thats all the info I could dig up on LS engines and cars installed.Last edited by mrr23; 04-28-2007 at 08:37 AM.
11-05-2007, 12:04 PM #2
- Feb 2007
- San Diego, CA
Very good and concise. 1 item though: Shouldn't the LS1 be 98-up F-body instead of 97-up?
If this is correct (I believe so) and it gets fixed then a mod can delete my post.
02-20-2008, 01:31 PM #3
02-20-2008, 01:48 PM #4
- Feb 2008
- Southwest Oregon
light grey- 1978 Volvo 242GT
Thanks for the comprehensive listing. Can I copy it for my own personal use in the future? Also, where exactly does the L33 fit in with all of this? My limited understanding is that its about 327 inches, 310 hp, 330 tor., all aluminumumm 4th gen and was/is offered in '04 and later extended and crew cab light Chevy/GMC pickups with 4WD? Thanks again.
02-22-2008, 10:57 AM #5
L33- 2005 - 5.3L 96.01 x 92 mm- Aluminum Block -285-315 hp/ 325-335 tq (aluminum block basically of the LM7)
2005-2007 1500 Extended cab Chevy and GMC 4wd trucks.
New arrivals as well
LSA/LS8/LS9 -2008 - 6.2L 4.06 x 3.62mm- Aluminum block with a 6th gen Eaton TVS R2300 roots 4-lobe supercharger, with an intercooler integrated into the intake- 475 (LS8 rumored)- 620+ HP. Forged bottom, titanuim rods, built alongside the LS7 by hand at Wixom.
LS9 2009+ ZR1 620+ hp,
LSA 2009+ CTS-V 550
LS8 2009+ Zeta chasis vehicle (no official announcements yet confirming or denying or what to put it in)
You can use this anyway ya need btw.
03-06-2008, 07:04 PM #6
how much hp will an ls1 block hold before cracking any webbing or anything else?
Red '02 Camaro Z-28
Black '06 H.D. Streetglide
Vibrant Blue '07 Dodge Hemi Crew Cab
05-07-2008, 05:59 PM #7
- Feb 2007
- new orleans
red- 2001 trans am
really needed this info. thanks
05-23-2008, 03:53 AM #8
i have seen ls1 blocks hold 1000 hp +
07-30-2008, 07:58 AM #9
- Apr 2006
- Terry, MS
few questions
Aluminum Block VS Iron Block?
LM7 vs LM4 ..... if one was searching for a 700RWHP capable block for a turbo engine to run around on the street..... is there any significant difference in the strength between these two blocks?
Also.... if one wanted to build a 5.3...... could you install the L92 heads (originally for the 6.0 which has a larger bore)..... and if so... will the stock style truck 5.3 intake work?
I assume I could install a Z06 ... or LS1 vette camshaft into a (say 2000 model) 5.3 truck engine?
Sorry for the ignorance.
07-31-2008, 09:29 PM #10
I don't really know the RWHP ratings in the Aluminum vs iron blocks. However there is an increase in strength between the two favoring the iron blocks, couldn't tell you exactly much though sorry.
As for the L92 heads on a LM7 or LM4 no. The valve placement is designed for a 4" bore (101.6 mm). Anything smaller than a 6.0 block (4"bore) will not work. Intake wise the L92/LS3/LS7 style heads (gen IV) are square port wheras the 5.3/5.7/6.0 LM/LS1/6 (gen III) style use cathedral ports.
The camshaft will work but you'd probably be better off ordering a custom grind as the specs on those cams are rather mild especially on a smaller displacement engine.
08-01-2008, 12:18 AM #11
I had an 02 1500HD that was a 6.0. LQ9 I think. It was rated at 300Hp and 330 or 360 lbs tq.
dale
08-02-2008, 11:22 PM #12
With the 300 rating it sounds like the LQ4 (300 hp 3760 TQ)which is only a lower compression version of the LQ9. LQ9's had 345 hp rating and according to GM were only available in the cadillac trucks in 02.
08-03-2008, 06:23 AM #13
08-22-2008, 02:58 PM #14
Ls1 or Ls6???
Hello everyone
Ok this might sound weird but is there any truth to the rumor that there were 30,000 Ws6 from 1998 to 2002 given an Ls6 instead of an Ls1 because of overage.
I know this sounds funny but 3 weeks age something strange happened to me. I was driving around my area and pulled up to a 2006ishbody style yellow Cobra mustang at a red light. I told the drive nice ride and if it was a real cobra he smiled and said yes than hit the gas it sounded deep but I have hard deeper before. The streets were pretty clear so we waited for the green light to see what’s what. I hooked pretty quick and killed him at the light I saw him catching up so I floored it and it was not even close I was killing him by 2 to 3 cars easy. We hit another light and I told him to stop playing and really lay into it he looked pretty upset and asked what I had I told him nothing but stock. He called me a liar and told me to F%^K off, he felt I have had to have something. I know I do not have stock exhaust, but even So can anyone help?
This might sound we
08-22-2008, 03:43 PM #15
The complete LS6 (Z06 engine) was never installed in an F-body from the factory. However, there was a shortage of LS1 blocks in the 2001-2002 model years, so the LS6 block was substituted in its place. It offers no real advantages over the LS1, it won't make any more power or anything, its just that its the LS6 casting.
08-22-2008, 05:37 PM #16
Thanks for clearing that up I am pretty new to the F-body scene. Still felt good pounding on a mustang....
So how would you be able to tell if you have a Ls6 instead of a Ls1? One more thing I read somewhere (can't remember the site ) that a 2001 and 2002 was rated at 385Hp and can ran a 12.9 in the 1/4 mile is that true?
08-22-2008, 08:47 PM #17
nice kill i love that look and the bein told to f--- off lol I had a guy in what I thought was a stock /with a flow master GT race me 5 times one night each time coming up with another reason why i walked 4 cars no him. come to find out the next night from my then gf that mustang wasnt a stock GT but one of those bullet mustangs the ones ford made and told everyone they would not only challenge the LS1 but walk right by it yall remmeber those? lol anyway i had to call him on it and sure as shit it was and i got told i was just another LS1 Asshole lol anyhow so from then on the crew i ran with ALL ls1 f-bodys started callin ourselves the ls1 assholes lol then even made a thread on their lil mustnag website like ours called ...run ins with the ls1 assholes ...basicly tryin to figure out what mods we had on what cars lol
08-22-2008, 11:47 PM #18
- Aug 2008
- NorCal
Black T-Tops- 2002 Camaro SS M6
LS1 = amazing
09-11-2008, 04:34 AM #19
In most cases GM, Ford and, Chrysler under rate the horse power, Has the ls1 been dyno tested to show any diff in factory rating?
10-08-2008, 11:30 AM #20
- Oct 2008
- St. Charles, IL
Navy Blue Metallic- 1999 Trans Am WS6
"LS1 Assholes" - Nice!
Question: Info on Engine combinations
By Bama99z in forum Internal EngineReplies: 12Last Post: 06-23-2009, 05:52 AM -
Small Block Chevy Engine - Build Your First Engine - Tech
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 01-30-2008, 07:50 PM -
1972 350 Chevrolet Pickup Engine - Tech - Build Your First Engine
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 09-29-2007, 06:50 AM -
How To Clean Your LS1 Firebird Engine Bay - Late Model Engine Bay Cleaning
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 04-24-2007, 01:20 AM -
Anyone have any info? (Computer info)
By blackSS01 in forum Almost Anything GoesReplies: 3Last Post: 02-01-2007, 01:44 PM
