Thread: Problems after header install
10-29-2015, 05:22 AM #1
Okay so hooked up the longtubes and o/r y pipe last weekend and now have code galore. The car had 50k miles on it before with zero CEL or problems.
PO102
DTC P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
PO803
DTC P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
PO135
DTC P0135 HO2S Heater Performance Bank 1 Sensor 1
PO141
DTC P0141 HO2S Heater Performance Bank 1 Sensor 2
PO155
DTC P0155 HO2S Heater Performance Bank 2 Sensor 1
PO161
DTC P0161 HO2S Heater Performance Bank 2 Sensor 2
So it looks like all of the o2 sensors are throwing a code and I am almost positive I have them plugged in the right spot. I plugged the front 2 sensors by the motor with the extensions to the header and the rear 2 are capped.
The car is running like SHIT (way down on power) and I just want to get it running right...Could an exhaust leak cause the front o2 sensors to read a bad signal? Sounds like it might have a small leak.
What do I need to do?!?!?? Help please
EDIT ---- http://www.ls1.com/forums/f6/please-...-p0102-157210/ -- According to this thread a fuse could have blown??? Which would explain the Skip shift solenoid and the hard time getting the car into reverse?Last edited by Z28YOUHO; 10-29-2015 at 05:27 AM.
10-29-2015, 06:55 AM #2
Check your wire harness, you may have pinched or burnt a harness. That's what I would check 1st.
O2 sensors - did you change them, how many miles on them? Over 70,000 -they need replaced about every 80,000. But this should be an issue just a fyi.
Transmission check the harness and sensors for the transmission. It's possible you damaged one getting them in. Couldn't hurt to check for a blown fuse. I'm not an auto guy so my knowledge is limited.
With the rear O2's deleted you will have a CEL on till you can get them tuned out. It will also make the car run a little crappy but it should still be able to drive it. I drove 4 moths till I sent my ECM to Frost.
10-29-2015, 07:26 AM #3
Thank you for the response. The car is an M6 and not an automatic with 50k original miles. The o2 sensors were working fine before I did the longtubes. I understand that the CEL will be on until the rear o2 are tuned out but to my knowledge the rear o2 only read if the cats are working properly and will not effect drive ability just cause it to run a little rich.
With the AIR removed is there a vacuum line that has to be patched up? All I did was disconnect the tubes from the old headers and pull of the rubber hose going to the pump near the back on the manifold.
ALSO - Would one burnt or pinch o2 sensor wire cause both sensors to throw a CEL?Last edited by Z28YOUHO; 10-29-2015 at 07:32 AM.
10-29-2015, 08:02 AM #4
In the right spot yes it can effect the harness.
The skip shift sounds like you may have cracked it, it's not connected or the harness is pinched/burnt.
The PO135, PO141, PO155, PO161 codes are for both O2 sensors, front and rear. You said you used extensions where these made or bought? Did they come with the headers? I almost want to say get a pair of Bosch 13111 O2 sensors ($60 ea) and see if at least 2 of those codes go away. The 13111's are for Corvette's and have a long harness that lets you eliminate the extensions. Some ppl have complained about issues with extensions.
The air pump you can pull the fuse from the fuse box that is in the engine bay on the drivers side. It will stop the pump from running.
It's been 5 yrs since I pulled the air pump and egr out.
These 2 threads should be used as a guide. Look over and see if you missed something.
http://www.ls1.com/forums/f63/header...l-pics-133419/
http://www.ls1.com/forums/f6/seconda...emoval-130641/
10-29-2015, 09:40 AM #5
The extensions were bought from the place I got the header from - the driver o2 was actually burnt a little but did not go through the wires (ordered new ones they'll be here today) If this doesn't fix the issue I am going to buy the Bosch 13111's and see what happens.
Thanks for the help man!
10-29-2015, 12:38 PM #6
If those don't work let me know. I just took my extensions off that I've been using for the last 5 yrs. I just put on Bosch 13111's for my tune session in 2 weeks so I still have them if you want to use.
00 FB Vert - Stock
Install shop or DIY header install?
By dethinboots in forum External EngineReplies: 7Last Post: 09-24-2011, 06:35 PM -
Post LT header install header issues
By ob02z28 in forum External EngineReplies: 20Last Post: 02-18-2010, 04:10 PM -
If u dont want problems after header install
By metalmechanic in forum External EngineReplies: 26Last Post: 06-05-2009, 12:06 PM -
Help! Header Install Problems!
By Hector in forum General HelpReplies: 3Last Post: 03-01-2007, 12:18 PM -
problems to expect after header install
By 98redbird in forum External EngineReplies: 4Last Post: 01-27-2006, 07:37 PM
