Page 1 of 3 123 LastLast
Results 1 to 20 of 46
Thread: Guess My RWHP??
    Member WS6SP33D's Avatar
    Nov 2011
    QuarterMile, KY
    Red w/ silver Stripes
    2000 WS6 6 Speed
    Talking Guess My RWHP??
    I have started on my swap. I have done a few of these so i know around the number it's going to have when finished. So let's see which of you guys get the closest.
    Mods are
    1 3/4 LT's
    Magnaflow CB
    ORY
    LS6 intake
    Volant twin cone cai
    243 heads
    prc 650 springs
    G5X3 cam
    TF pushrods
    Spec 3 clutch
    new tune
    Running through a m6 with stock 10 bolt.
    I will be taking my time on this one since it's winter and not in a hurry to drive lol.
    USA
    Velocity Yellow
    2008 Corvette Z06
    My guess is around the 430 region on a Mustang dyno. But that's just a guess, no idea what those cam specs are.
    I'll say 438 rwhp.
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    id say just north of 400
    spring pushrods and clutch arent really gonna add any power
    1 3/4 headers and the LS6 intake (both of which I have) are limiting you a little at this point
    but yeah..your set up is similar to what i have/working on
    Nov 2011
    QuarterMile, KY
    2000 WS6 6 Speed
    I'll say 438 rwhp.
    ^^ both of you are dead on the last 01 i did with these mods it was 334rwhp lol
    clutch slipage is a big issue any time you dyno. Thats the only reason i listed what the setup was.. Don't understand what you mean by limiting me at this point? For the supporting mods and the 100's of installs i have done and dyno'd. If your suggesting a set of 1 7/8 lt's and a fast intake would make a big difference, then no it wouldn't. I have had many customers come in after spending $1400 on intake and tb and pick up 5hp over a worked ls6 and 11 over a stock ls6.
    USA
    Velocity Yellow
    2008 Corvette Z06
    Quote Originally Posted by WS6SP33D View Post
    ^^ both of you are dead on the last 01 i did with these mods it was 434rwhp lol
    Fixed.
    Nov 2011
    QuarterMile, KY
    2000 WS6 6 Speed
    Fixed.
    Thanks for the catch konigandy6 . I have been taking pictures of the steps as im going. i will make a heads, cam swap thread as soon as finished.
    sick & twisted SS 02_slp_ss's Avatar
    Jun 2009
    Chambersburg PA
    2002 SS camaro
    Is this cam close to an ms4 by chance? I have the same mods besides the cam an a 9" rear
    MS3 cam, harland sharp 1.7, pac 1518 sprins, ported 241 heads, LT, 3in E-cutout, Ram stage 2 clutch, 13 lb fly wheel. << 443rwhp 451rwtq>>
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    422 hp is my guess. When will we know the results and what is the top prize ? lol
    May 2010
    Wilkes-Barre, PA
    Black/Black
    98 WS6/04 Sierra Dmax
    I will guess 426RWHP & 390RWTQ Winner wins the car??? haha
    Callies 383, Trick Flow 225, Rapid Motorsports Dominatior 2 X cam, ls6 ported oil pump,42lb injectors, FAST 92/92 , ASP underdrive pully, eletric water pump, Pacesetter LT's, Pacesetter ORY, Magnaflow catback, e-cutout, Yank SS 3600, Performabuilt stage 2 4l60e, Strange S60 ,4.10s, Detroit Truetrac, (UMI) - Adj. LCA, Adj. tunnel mount torque arm, Adj. panhard bar, Drag bar, subframe conectors, shock tower brace. 465rwhp-438rwtq 11.09@119.90.
    Nov 2011
    QuarterMile, KY
    2000 WS6 6 Speed
    ^^ LMAO Going to try to dyno wed if everything goes well. If not should be for sure thurs. And im not sure on the specs of a ms4 right off the bat.
    2000 SS Black M6
    What I meant was, your heads and cam are as big as you can go with those heads and intake. So yeah, you're right, a bigger intake wouldnt get you much....right now....but if you did anymore internal stuff, youd be suffering.
    And if youve done hundreds of these installs....why are you asking us to guess your numbers?
    Nov 2011
    QuarterMile, KY
    2000 WS6 6 Speed
    ^ ok I gotcha. And I started this just to get some activity on the forum lol.
    Re-subscribed. My mobile post didn't add this to my subscribed threads for some reason.
    May 2010
    Wilkes-Barre, PA
    Black/Black
    ^^ Jeff, that happens all the time to me when I post with the app.
    May 2010
    Wilkes-Barre, PA
    Black/Black
    Any numbers yet??
    Nov 2011
    QuarterMile, KY
    2000 WS6 6 Speed
    Quote Originally Posted by cpop98ws6 View Post
    Any numbers yet??
    No sir. The swap is complete other than a warm up then oil change and tune. I have had 2 customers pull me off my car to fix theirs lol. I plan on finishing ones fuel system up tomorrow and getting back on mine tues. Then to start on the 9" woooo
    May 2010
    Wilkes-Barre, PA
    Black/Black
    I'm just finishing up my s60 install as I type this. Another half hour and ill be taking it for i test drive!
    Don't forget to update your tune for the new gear ratio. Looking forward to hearing what you think of the 4.10's.
    Nov 2011
    QuarterMile, KY
    2000 WS6 6 Speed
    Awesome lets us know how it drives. I got my setup ready for next week
    Moser 9"
    Strange third member
    430 gears
    Full Spool
    40 spline Moser axles
    UMI torque arm with tunnel brace
    Driveshaft loop
    UMI diamond sub frame connectors
    AGX 8 way adjustable shocks
    UMI double adjustable panhard bar
    Double adjustable LCA's W/ relocation brackets
    Sphon Weld in pro series sway bar.
  1. Guess what I just did
    By Spikito in forum Almost Anything Goes
    Last Post: 11-30-2009, 11:10 AM
  2. Guess it!!!!
    By blackSS01 in forum Almost Anything Goes
    Last Post: 11-24-2009, 01:37 PM
  3. Question: Best guess on rwhp
    By obnxousta in forum Internal Engine
    Last Post: 02-21-2009, 03:28 PM
  4. 550 RWHP 383 Z06 VS 770 RWHP Supra MKIV
    By LS1 RX7 in forum Kill Stories
    Last Post: 02-02-2007, 04:47 PM
  5. I guess I am a new bee once again....
    By Blue69 in forum New Member Introductions
    Last Post: 08-24-2006, 02:59 PM
