12-07-2011, 03:09 AM #1
- Aug 2007
- North Carolina
oil filter fitting on new oil pan
I bought a 2002 Transam motor pull and had to replace the oil pan. I purchased a OE oil pan from one of the GM parts sites.
I have bought 2 oil filters and they both are too small od thread diameter to screw on to the filter adapter.
According to the parts list I should have a 13/16" x27 oil filter fitting but I don't. Mine is larger.
Anyone know what could be going on?
12-07-2011, 03:33 AM #2
What filter part numbers and oil pan part number?
12-07-2011, 03:37 AM #3
- Aug 2007
- North Carolina
I am not sure of the new pan #. I bought it so long ago. I am going to check the old pan and see what size the fitting is. I may just remove it and put it in the new pan.
There may be a metric thing going on here.
12-31-2011, 10:39 AM #4
- Dec 2011
- Conroe
alloy (charcol gray)- 1979 camaro z28; 2010 Cad
PF48 or PF61should do the trick, if it doesnt go to dealer and buy the thread coupler for the filter for the application the motor came out of, it simply unscrews with an allen socket:-)
01-02-2012, 09:10 AM #5
- Aug 2007
- North Carolina
Got it figured out. Bought the allen wrench style fitting and filter fits fine.
Thanks guys
01-02-2012, 04:45 PM #6
- Dec 2010
- Las Vegas
- 2006 DD
I had the same issue when I went with a 07' LS2 oil pan from a C6 vette, the fitting on the pan was a larger diameter
Best Fitting ORY?
By WS6Dream in forum External EngineReplies: 34Last Post: 07-29-2011, 07:40 AM -
Oil fitting-new!
By Jarlaxle in forum General HelpReplies: 2Last Post: 11-21-2009, 11:46 AM -
Question: Fitting a WS6 airbox on a Z28?
By Y2K_CAMARO in forum Camaro / SSReplies: 15Last Post: 10-10-2009, 12:39 PM -
fuel fitting
By 02sscamaro in forum General HelpReplies: 2Last Post: 05-26-2007, 01:06 AM -
problem with K&N filter fitting loose
By mvvette97 in forum General HelpReplies: 7Last Post: 08-30-2006, 03:47 PM
