Results 1 to 20 of 22
Thread: Purge
    Rice Killa JwMonE99's Avatar
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Purge
    How important is it to have a purge set up?
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    not real important. when i didn't have one, i would purge through the motor during the burnout.
    Member RealLiveMD's Avatar
    Feb 2006
    Memphis
    2002 WS6
    Quote Originally Posted by JwMonE99 View Post
    clears all the air out of the line...making your hit harder. However, if you're spraying in 1st or 2nd, then you probably want a softer hit. Well... that's if you are on street tires.
    Now the rice factor,.... priceless!
    orlando, fl
    2014 camaro 2ss/rs
    technically, you only have air in the line when you disconnect the bottle from the line. other than that, what you are doing is getting liquid nitrous up to the solenoid. over time, due to heat, the nitrous in the line turns into a gas form. you only want that to happen when it hits the nozzle. the nitrous doesn't seperate from the nitrogen until about 650*F.
    Member NoscamaroSS's Avatar
    Durant, Okla
    2002 Camaro
    Definately helps it hit harder, ive actually stopped using my purge to help keep from shocking the tires so much when I spray.
    02 Camaro
    PRC Stg 2.5 5.3's, Futral F14, PP Typhoon intake, True duals, Performabuilt tranny, & 3500 convertor, HSW plate kit.
    *Old Time* 10.90@ 125mph
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    So bottom line is it worth getting?
    Im most likely going to get an RPM window to lock it out of first gear only.
    orlando, fl
    2014 camaro 2ss/rs
    in that case, no. again, you can just purge through the motor while doing the burnout and you're good to go.
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    What do you mean purge through a burnout if I got no purge?
    orlando, fl
    2014 camaro 2ss/rs
    as you do your burnout, you turn on the nitrous system and use it for a second or two.
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Yea but if I have the window switch and lock it out of 1st gear how would it work?
    orlando, fl
    2014 camaro 2ss/rs
    it wouldn't. for got about the first gear lockoout. just don't worry about the purge.
    Member wenn_du_weinst's Avatar
    Aug 2008
    South Dakota
    use second gear for the burnout?
    Jun 2009
    jacksonville, fl
    liquid red
    2008 Pontiac G8 GT
    Just a quick question but isnt that car in your avatar purging or is just steam? Just curious.
    orlando, fl
    2014 camaro 2ss/rs
    purging back when i had it going that way.
    In need of another LS1 00blacktransam112's Avatar
    Aug 2008
    Sutton MA
    2000 Pontiac TA
    purge looks so cool though. id do it just to show off
    Junior Member Ryans_Pewter_SS's Avatar
    Aug 2008
    North Carolina
    2002 Camaro SS
    Here's mine
    Aug 2008
    Sutton MA
    2000 Pontiac TA
    Quote Originally Posted by Ryans_Pewter_SS View Post
    Here's mine
    beautiful
    Aug 2008
    North Carolina
    2002 Camaro SS
    Thanks! You should see it on a cool night! Its intimidating! And can back it up when i spray and put 730hp to the ground!
    Aug 2008
    Sutton MA
    2000 Pontiac TA
    HOLY SHIT. those are some pretty impressive #'s
    Aug 2008
    North Carolina
    2002 Camaro SS
    Thanks!The torque was 738, It was fun, I'm doing another motor and should be done by the end of the year, 418 Ls3 stroker with a 250 shot direct port. Should be nasty!!!
  1. Question: Where to purge?
    By derekbuckner1 in forum Nitrous
    Last Post: 02-18-2015, 03:40 PM
  2. purge sol.
    By Whiteboycntdnce in forum Nitrous
    Last Post: 07-13-2007, 08:24 PM
  3. Zex Purge
    By DeadZ28 in forum Parts For Sale / Trade
    Last Post: 02-23-2007, 06:55 PM
  4. FS: Dry NOS kit w/ purge kit
    By tibshark in forum Parts For Sale / Trade
    Last Post: 07-05-2006, 07:54 PM
  5. F/S: ZEX purge kit
    By nevrlift in forum Western Members
    Last Post: 04-13-2006, 08:16 PM
