Thread: 4L60E Question
    Jun 2013
    Macedon,NY
    Light pewter metallic
    2000 Camaro SS vert
    4L60E Question
    So my SS as it sits has around 69K on it. I have owned it for almost 5 years. The only thing I haven't done to it is have the transmission serviced. I called the dealer that is literally right across the street from my house and they said that they flush the system out but don't change the filter but flush it. Is that a common thing??? I am a little leary about that. Would like peoples thoughts on it. Thanks.
    Sep 2013
    pa
    2004 gto
    4L60E Question
    The shop i ran always gave you the option of changing the filter and then flushing trans . On my personal vehicles I always changed the filter and refilled the fluid and then flushed it . I could definitley tell the difference when it was done . It costs more to do it that way but doesnt compare to the price of a new trans .
    Servicing the transmission is quite simple. I have never had a garage "flush" any of our transmissions. The theory behind flushing is that you change all the fluid as simply dropping the pan will leave quite a bit of transmission fluid remaining in the converter (2-3 qts). I always change the filter and replace the pan gasket. So long as you service it every 50,000 miles or so you should be good. Bring it down and we can do this in a couple of hours...
    Mar 2011
    fort myers,fl
    1998 trans am convertible
    WHAT automatic tranny fluid do you use? I have it changed every 30,000 miles. is one brand better than another for a car that is mostly city driven? i have a 120, 000 miles on this tranny so it is due.
    I think I am running Castrol Dex VI right now.
  1. ls1 gto 4l60e question
    By jesselee83189 in forum Automatic Transmission
    Last Post: 06-11-2012, 04:00 AM
  2. 4l60e question
    By oldpurple73 in forum Automatic Transmission
    Last Post: 05-19-2012, 08:01 PM
  3. 4l60e Question
    By PFM in forum Automatic Transmission
    Last Post: 08-03-2008, 05:09 PM
  4. 4L60E question plz help
    By dto in forum Automatic Transmission
    Last Post: 07-16-2007, 10:11 PM
  5. question about 4l60e's
    By 98Z-28Camaro in forum Automatic Transmission
    Last Post: 03-06-2007, 07:51 PM
