Results 1 to 20 of 20
    Member SpeedWorld's Avatar
    Minnesota
    How about a best way to launch my M6 thread?!
    So as some of you know I have only had my car around 3 weeks. I have been taking it easy on it. I am on the stock rear end and stock gears. I subframe connectors, pandhard bar, control arms, and 387hp to the wheels. Oh yeah, I also have Nitto NT555r Extreme 2 tires on it, which I believe are drag radials. I am worried about busting my rear if I launch to hard because these tires stick and I dont want to start hopping. Any suggestions on what I should launch at, both on the street and at the track?
    USA
    Velocity Yellow
    2008 Corvette Z06
    I would also like an answer to this question. I have had my car for about 4 months now and I've been to the track once. From a roll racing I have no problem at all. But from a dig, I can't seem to get it right. I dont know if it is the excitement or adrenaline from the race, but I always seem to give it wayyyyyy to much gas and peel out all throughout 1st gear. My best run at the track was a 13.56 and that was all stock. (today's mods below) So how do all you professionals launch your cars good?
    2018 Tahoe - Silver - OEM
    2 SS's are better than 1 Jays00ss's Avatar
    Lathrop, Missouri
    NBM / Silver
    00 SS / 71 SS Elcamino
    ya buy a ford 9" with sticky tires launch around 3000 rpm
    Rice Killa JwMonE99's Avatar
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Ok with the people that doesnt have the money for a 9 inch, at what RPM should we launch at?
    Milwaukee
    2000 Trans Am
    I launch at 2900-3200 depending the road and weather. I have some suspension most people i talk to with stock suspension launch at 2500-3000. You just have to practice, slippingthe clutch so you dont spin too bad nad so you dont let the rpms drop to far. And if you have drag radials and a 9inch you can launch a cammed ls1 at 4500rpms.
    Lathrop, Missouri
    NBM / Silver
    Quote Originally Posted by JwMonE99 View Post
    ok, Better have a buddy with a truck and a trailer. Your 10 bolt will eventually let you down. I have seen it time and time again. Especially with a M-6. Around 2300 is about the best.
    Milwaukee
    2000 Trans Am
    It is different between cars what you can launch at, the tires, suspension, other conditions, when i launch at 3000rpms, i squeal a little but it never gets sideways or anything, unless i want it to. When i shift into second hard it spins them but once again just for a secodn and i chirp goin into 3rd. I ran a 1.947 60 foot. Which i think for stock size tires is pretty good. That was my best time, most of them were low 2.00s
    IL
    06 HD Softail
    1998 Trans Am m6
    2500-3000 rpms is what I launch at and it seems to work alright.
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    So even at like 2500 it will break?
    What about races from a roll? do they still break?
    IL
    06 HD Softail
    1998 Trans Am m6
    roll races dont hurt rear ends like a launch does...
    Senior Member splitfinger09's Avatar
    Bartlesville, Oklahoma, United
    Bright Rally Red
    2000 Camaro SS #5075 M6
    yes at 2500 launching on stock tires you will spin. I dont know about you guys, but from a roll at 3000 i dont see traction until i shift into 3rd. Im mostly stock with a loudmouth 1 and sfc's. LS1 ftw
    Aug 2006
    St. Louis
    Quote Originally Posted by Jays00ss View Post
    we are trying to get advice for launching with a 10 bolt and NOT breaking it... you cant possibly tell me that these cars cant launch with stock 10 bolt and don't bother, go buy a 2500 rear end. most of us cant afford this.
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by Twigs View Post
    When I went to the track I feathered the throttle between 2000-2500RPM and just came off the clutch quickly when I got the green. I netted a 2.157 60' time. DO NOT drop the clutch (unless you have a 9" or 12 bolt and sticky tires) because all that will do is shock the driveline and result in ridiculous wheel spin.
    I have 285/40 Eagle F1 DS-G3's out back, and even at that low of an RPM, in 90 degree weather, I still spun off the line and spun pretty hard going into 2nd.
    aurora colorado
    2002 TRANS AM WS6
    i could only guess at the rpm say 2000-2200 i just wait for the second amber to light up then floor it and drop the clutch at the third amber. my 60 ft. are in the 2.3-2.1 range, with the tracktion control on. oh and by the way my car dynoed at 642 rwhp corrected, in Denver it's more like 533. it's been almost a year now at those levels
    Vista, Ca
    Blue
    03,EB Z06
    I like to launch around 2200-2500 rpm and quickly, but evenly ROLL on the throttle. So the tires spin a little but dont light up.
    Member ApexVIII's Avatar
    Modesto, CA
    1998 Camaro Z28
    just dont dump the clutch with sticky tires that will help alot! just slip it alot lol
    M6, Lid, Ported and Polished Throttle Body (By Me!), LT, Custom Catted Y, Electric Cutout, PHB, LCA13.21@108 with a 2.3 60'
    Member stanger88's Avatar
    Shreveport, LA
    Black on black.
    2001 WS6 M6 (stock)
    VERY GENTLY until you get a Ford rear end under it. You can blow a 10-bolt gently taking off at a light at an idle sometimes. Be careful and have fun.
    Member pinky93's Avatar
    Houston, Texas
    Onyx Black
    2002 Camaro SS
    My 02' SS lived with the stock rear with a T/A differential cover w/ bearing girdle. It actually just prolonged it's life, but it lasted for me luckily. I ran Nittos DR's and launched at the track at 4,800 one time with an M6. It was a big mistake and I didn't mean to do it, but that beeyatch left like she was shot out of a cannon!! Too bad when I hit 2nd, the clutch gave it up....
    This 2000 T/A is all stock, but I am changing all the fluids and have a Pro 5.0 purchased and will be getting another T/A cover. I know it won't save it, but if I get better at leaving, maybe it will be with me for a while....
    2002 Camaro SS - SLP # 7744
    SLP SFC
    SLP Blackwing
    SLP Panhard Bar
    SLP LCA's
    SLP 85mm MAF
    SLP 160 degree stat
    SLP Y-pipe
    Diablo Tuner
    Member Orange99z28's Avatar
    joliet il
    orange
    99 z28
    i only launch at like 2k, any more than that and they spin. thats on the street though. at the track i coulda launched much higher, but look at it like this, with a stock rear end theres not much to be gained by pushing it that little bit extra. chances are you'll just break it. my perfect launch is at 1900-2k getting a mild squeal through first, just experiment on street tires (save your rear end), its pretty quick work to figure out how muh gas'll break em loose, then just give it a little less untill u stick. after you get that down you can switch to dr's if you want (i really wouldn't recomend it unless u got some serious $$). if you want a good launch buy new clutch and rear end or stick to street tires. dr's aren't garunteed to break the rear, but thats an expensive maybe...
    plus i'd rather be able to do donuts and such, dr's are def. not your friend for that kinda fun!
    chicago
    bright red
    2000 ss conv.
    DONT DROP THE CLUTCH 8 passes and (KABOOOOOOOOOOOMMM) now spending $$$$$$$$$$$$$$$ for s60 strange dana rear end. like someone nuked my car!!! not to mention tow expence when a long way from home!! DDDOOOONNNNTTTT DO IIIIIIIIITTTTTT!!!!!
  1. ps4 launch thread
    By chuckie669 in forum Computers / Gaming
    Last Post: 11-13-2020, 03:13 AM
  2. Should I launch it?
    By LeadFarmer in forum Drag Racing
    Last Post: 04-29-2013, 09:26 AM
  3. New best and new launch pic again, lol...
    By rel3rd in forum Drag Racing
    Last Post: 01-30-2008, 06:51 PM
  4. How do you Launch ?
    By Bottesini in forum Drag Racing
    Last Post: 09-16-2007, 01:10 PM
  5. Replies: 22
    Last Post: 11-26-2006, 08:54 PM
