Page 8 of 12 FirstFirst ... 456789101112 LastLast
Results 141 to 160 of 231
  1. #141
    Member the951racer's Avatar
    Mar 2012
    Jackson, MS
    Copenhagen Blau/Black
    88 Porsche 951/07 TBSS
    How is the chatter and overall drivability of your Spec 3?
  2. #142
    Mar 2012
    Jackson, MS
    Found out that Spec has conversion clutch packaged specific to my build. That's what I'll be getting!
  3. #143
    Mar 2012
    Jackson, MS
    Update! All accessories and flywheel are on as well as ATI Super Damper and SLP double roller.
  4. #144
    Junior Member FIREHAWKSLP's Avatar
    Mar 2013
    San Antonio,tx
    dark metalic green
    91 firbird formula WS6
    Exclamation advice on a clutch what to avoid?!!
    Quote Originally Posted by the951racer View Post
    What you need in a clutch to avoid chatter:
    1.) make sure the disc has a sprung hub ie that the center splined hub is circled by a group of coil springs this is what cushions that moment when the clutch stops slipping and couples up.
    2.) if possible see if the clutch friction material has a Macrel which is just a donut shaped pc of wavy spring steel this allows you that little bit of controlled slip to make that cool skilled take off from a dead stop, that says yes I am vary skilled at driving stick ; no chug,chug away for me or rev-bog and away
    3.) Stay away from the the puck style clutchs they are usually cut out so the have a number of arms anywhere from 3 to 6 usually at the end of each arm is a puck of sinister iron or bronze they hold like crazy but are brutal on the street because they act more like light switch either on or off with nothing inbetween are almost impossible to slip. Be warned they look cool as hell and you'll want one but unless your building track bullet you won't be happy but if it will only see duty on the drag strip this maybe a good match the matalic pucks are almost imune to heat. But again putting along in the stagging lanes will soon turn into pushing along the lanes.
    I hear good things about the LS7 clutch in a street driver but that it doesn't like repeated high RPM dumps that it is damaged and loses some of it holding power with repeated abuse. But on the other hand it's supposed to be a joy to live with, especially in DD, light pedal , easy to modulate, not terrible expensive.
    Speaking of the LS7 ZO6 the only time I have ever heard Jeremy Clarkson of TOP GEAR UK speak a word of praise about any american car was when they tested the Corvette ZO6 w/the LS7; because it had one vary cool party trick The car with him in it is at one end of the runway he puts into 5th lets the ciutch out slowly just a hint of chatter and then goes from zero to 175mph w/o shifting which he thought was amazing. He also thought the rest of the car was rubbish as the British say (american translation "crap")he kept compareing it to Ferrari which literally cost over 2&half times as much, I want to say it was the 430 predecessor to the current all conquering 458.
    Last edited by FIREHAWKSLP; 08-12-2013 at 09:00 PM. Reason: check spelling and run on sentences, didn't say I fixed it all just checking
  5. #145
    Mar 2013
    San Antonio,tx
    dark metalic green
    love the shot of the eng from the flywheel straight on flanked the collectors of the headers 2nd shot from the top. The amazing thing to me is how right the LS1 looks in the eng. bay of a 944/951 & presumably a 968 as well; all that power and torque in a small light highly capable and manuveurable chassis Damn that thing is going to be Jack from jack and the beanstalk ie a giant killer. All the great handling preserved with easally twice the power the NA 2.5L makes 150 horse IIRC A STOCK lS1 is more than twice that. I could never do this because if it turned out only have as well as I think it will. People would soon think me insane as drove around town gigling like teenage school girl just burb-a-ling along in it.
    I think I might risk it, just the same; somethings are worth the risk.
    94% of Americans say "OH SH=T!" as they dive into a foxhole the other 6% are from Texas and say "Here HOLD my beer and watch this
    "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety."
    Benjamin Franklin, 1759
  6. #146
    Aug 2013
    Chesapeake Va
    911 Red
    1984 Porsche 944
    Looks Awesome man! Im actually starting the same build on my 84 944!
  7. #147
    Mar 2012
    Jackson, MS
    Cool. Thanks for the info on the clutch setups. Think I'm going with the Spec Stage 2. Love Top Gear...def remember the episode your talking about too. Was a good one. The LS1 does fit and look amazing in the 944/951. Can't wait to finish her up! Gonna be pretty soon I hope!
  8. #148
    Mar 2012
    Jackson, MS
    Quote Originally Posted by 944juggernaut View Post
    You should set up a build thread and PM me the link.
  9. #149
    Mar 2012
    Jackson, MS
    Ball joints replaced, tie rod ends replaced and the suspension is buttoned back up with new stainless brake lines. Clutch ordered as well as larger radiator, Prosport gauges, and P&P throttle body and MAF ends.
  10. #150
    Mar 2012
    Jackson, MS
  11. #151
    Mar 2012
    Jackson, MS
    That was fast....clutch and gauges arrived today!
  12. #152
    Member initechpeter's Avatar
    Apr 2012
    Iowa
    2002 Trans Am WS6 - Red
    2013 Chevy Traverse LTZ
    Nice build.
  13. #153
    Mar 2012
    Jackson, MS
    Thanks a lot!
  14. #154
    Mar 2012
    Jackson, MS
    Less than 2 weeks away from the road trip to Texas Performance Concepts for completion and tune!!!
  15. #155
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    maybe its just me, but I think a bowtie or a camaro emblem would look perfect on the nose, right were that porsche emblem is
  16. #156
    Apr 2012
    Iowa
    He should use the same emblem he has for his sig. Overall great work.
  17. #157
    Henryetta/Tulsa Oklahoma
    2016 Camaro SS - Summit
    2001 Trans Am WS6 - NBM
    Quote Originally Posted by initechpeter View Post
    Pretty sure the avatar pic will be the new emblem...
    Oh and this is the crown jewel to finish everything off at the end of the build.......Click for full size
  18. #158
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Sorry, I never received the notification that this thread had been updated! I have no driveability issues with mine. There was some slight chatter during the initial break-in period. I've put about 15,000 miles on the clutch now and it still works well.
  19. #159
    Mar 2012
    Jackson, MS
    Hey guys! Yea the new emblem will be the one in my avatar pic. I'm working with a machine shop in the UK that specializes in making custom badges so that I can spread these awesome things around. Also, I ended up going with the stage 2 Spec. Figured it would hold the power ill be making just fine. This is the countdown to the final days of the build! Heading to Texas Performance Concepts on Friday to complete wiring/ECU flash, plumbing, and tuning! Can't wait to post some video and dyno numbers! Stick around and spread the word!
  20. #160
    Mar 2012
    Jackson, MS
    Here's what came in Saturday.....
    Remote master cylinder so my Spec Stage 2 keeps the factory feel!
  1. LS 944 Porsche
    By cfgioja in forum New Member Introductions
    Last Post: 08-21-2010, 11:26 PM
  2. Porsche 914-6
    By Z06-Goose in forum Showcar and Detailing
    Last Post: 10-08-2009, 10:56 PM
  3. 500CI Chevy LS1 Engine Build - How To Build A 500C
    Last Post: 02-17-2009, 07:10 PM
  4. me in porsche having fun
    By jimmybling31 in forum Kill Stories
    Last Post: 03-09-2008, 07:56 PM
  5. Porsche GT3-RS vs my 02 Z28
    By Mike's02Z28M6 in forum Kill Stories
    Last Post: 02-16-2008, 03:51 AM
