Results 121 to 140 of 141
Thread: LS6 valley cover in pics
03-03-2011, 12:07 PM #121
- Feb 2011
- AZ
black- 2000 Camaro SS
Looks like you have the short harness wire going to the front knock sensor, long wire to back? I did mine the opposite (copying from the old harness), but I could be wrong. Anyway if you ever get a knock sensor code, you might need to switch the numbers (#1 is really #2 and vice versa).
03-03-2011, 12:12 PM #122
i just put it in where it fit and reached without stretching the wires. No knock senor codes though so i guess i did it right lol. I tryed it the other way but the harness didnt fit right.
03-03-2011, 12:44 PM #123
- Jan 2010
- texas
silver- 2000 formula
those parts look familiar......
05-02-2011, 02:42 AM #124
LS6 engine toppers are working great so far
06-09-2011, 11:53 AM #125
- Jun 2007
- aurora
I started doing this on my '01 ws6. I am about to open up the old cover since I already took off the intake. What is the part number for the ls6 cover? Also someone mentioned they got a OPSU for about $10, where at? I am a complete beginner to all this and I am surprised I've gotten this far without much help.
One more question, how do you know if your intake is ls1 or ls6? the number on it 12561184
06-09-2011, 12:04 PM #126
This will help with the VCT mod, part number is in second post
http://www.ls1.com/forums/showthread.php?t=145557
Your lucky you have a LS6 Intake
Stock 2001-2002 F-body LS6 is 12561184.
The Z06 LS6 is 12573572.
The old LS1 intake with the EGR setup is 12560688.
97-00 vette LS1 part # is 12556333
OPSU's go for about $50, $10 sounds like a private used deal.
06-09-2011, 12:32 PM #127
- Jun 2007
- aurora
06-09-2011, 12:39 PM #128
You most likely will have to. 02's are the only ones that for sure had the LS6 block. It's not hard, take your time, and make sure to cover everything so that you don't get any metal in the engine. I had a buddy used a shop vac as I was cutting, help minimized debris.
You can PM if you get stuck.
Only way to tell is to take it of and look for cracks. I'd go ahead a switch it out as well as the knock sensors and wire harness. All 3 are over 10 yrs old and have been through 1000's of heat cycles. Think of it as one of those preventative maintenance things.
The socket can be got for $10 at any parts store.
06-09-2011, 12:41 PM #129
- Jun 2007
- aurora
09-06-2011, 06:57 PM #130
- Aug 2011
- lindenhurst ny
black- 1999 camaro ss
i just did the swap about a half hour ago. definitly read the ls1howto and youll have no problems
11-06-2011, 01:17 PM #131
I am doing the valley cover conversion right now. Intake back on, working fuel rails right now. What about the connection at the brake booster? That hose is removed, but must we cap that off at the booster too or did I miss something?
11-06-2011, 02:55 PM #132
Very nice walk through with pics. Great work op
11-07-2011, 02:07 AM #133
11-07-2011, 04:26 AM #134
12-17-2012, 04:43 AM #135
- Jun 2006
- Central Missouri
Noob here reviving this, would an open element breather on the driver side valve cover where the pcv was be a good or bad thing? This is of course with the LS6 intake and valley mod.
12-17-2012, 04:59 AM #136
09-15-2013, 12:09 PM #137
ls6 intake gm part # 88894339
gmpartsdirect.com
or your local chevy dealer
09-29-2013, 12:02 PM #138
- Jan 2010
- texas
^^^ LS6 intakes on ebay all day long !!!
09-29-2013, 12:27 PM #139
pretty much, everyone starting to jump on old Fast intakes so they are getting rid of their LS6 intakes and with 4th gens starting to take a back seat to the 5th gen Maro and Vettes, parts are starting popup all over the place for us again
02-04-2017, 05:30 AM #140
- Oct 2009
- Midlothian, VA
Blue/Grey- 2002 Camaro
I know that I have not been on this site for quite a while, but I have been kina busy. My question is: 12577927 cover, 12594779 hose, 12562267OPSU, are these all of the parts I will need for the conversion on my '02 B4C car? I am preparing for this task. Thanks, Andy
LS2 Valley Cover
By PitchBlackLS2 in forum LS2/LS3/LS4/LSxReplies: 0Last Post: 11-28-2016, 06:49 AM -
Question: ls6 valley cover
By tangkiller_z28 in forum General HelpReplies: 7Last Post: 07-13-2011, 12:05 PM -
Valley cover
By sutie in forum Firebird / WS6Replies: 5Last Post: 02-24-2011, 05:07 AM -
LS6 Valley Cover and Catch Can
By ls1camino in forum External EngineReplies: 11Last Post: 05-20-2009, 08:23 AM -
LS! Valley Cover
By parbreak in forum Parts For Sale / TradeReplies: 0Last Post: 04-22-2006, 06:26 PM
