Results 121 to 140 of 155
Thread: Whats nitrous like?
06-04-2007, 08:23 AM #121
Nope! Sure haven't changed out the springs yet! Great tip! I thought the handled well in comparison to all my buddies Mustangs (d'oh! I do associate with F$*# owners too) but if it can be that much better using factory 6cyl springs, I'm down for giving that a shot!
(pun intended!)
-Eagle
06-04-2007, 08:37 AM #122
06-04-2007, 10:16 AM #123
if u do the 6 cyl springs it will lower the back of your car a little bit (not exactly sure how much)
so id recomend cutting 1/2 or a full coil off your front springs to even it out.
not sure exactly how much to cut either, just guessed... maybe someone else on here can suggest that
06-04-2007, 10:34 AM #124
It all depends on the car......We have had some that sit level still and other that were a inch lower in the rear.
I would ONLY cut 1/4 coil at a time!! I learned that the hard way.
Make sure you put some type of weight in the car to as if you were sitting in it to get accurate measurements.
Anyways put them in and just see how it sits.......
06-06-2007, 06:47 AM #125
- Apr 2007
- dont worry about it
Red- 01 Z28
man just throw the bottle on that thing u will love it, as long as u set it up safe ur golden. i have been running a 100 shot for two years no problems at all
06-06-2007, 06:48 AM #126
- Apr 2007
Red- 01 Z28
make sure u change your plugs often though some people just let it go for a while
05-02-2010, 04:26 PM #127
05-04-2010, 05:07 PM #128
- Dec 2005
- Tampa, FL
Pewter- '00 TransAm WS/6
I'll just add my 2 cents.
I put a dry system on my '98 TransAm (with automatic). It made it a bit quicker. I think it was jetted for 75hp.
After I had my '00 WS/6 for about a year, I decided it was time to move the system over. I rejetted it for 150hp (approx 500hp total). I went to a local shop to get the tank filled, and one of the guys there wanted to come along to the track (Pomona Raceway). Sure, why not. I staged with the NOS off (switch on the dash). I hit the switch so it was enabled once I got to the start line. I floored it, and after about 20 feet, the RPM's jumped up. I got off the gas and tried again. Again, no added forward speed, but now I could smell smoke. The radio was tuned so we could hear the announcer. We got the bad news quick "uh-oh, it looks like he has problems". We finished at a whopping 50mph. We pulled off the track, stopped, and there was smoke rolling out from the clutch.
There's a delicate balance to everything in your car. When you start bumping up the power significantly, things can break. Lucky for me it was just the clutch. I bought a racing clutch (don't remember the brand or model, it's been a few years), and planned on doing it again sometime.
I did use it a few more times, just fucking around. It (obviously) wasn't like on TV. Quicker, sure, but not shit my pants amazing.
Rather than running with the NOS, I've made other changes to be quicker on the streets. Just little things. Better Y pipe, lightened flywheel, and improved the air flow from the nose to past the throttle body. I haven't used the NOS in quite a while, and really don't see a need to. The car performs beautifully, I don't need a bottle to feed my baby. If I want to play with someone, they're looking at my taillights in the distance.
Unless you're racing on a regular basis, and plan on doing upgrades because you fuck things up, I'd recommend putting better stuff in than the NOS. What else could break? All kinds of things.
My '82 Firebird started life with a 2.8 V6. I dropped a 4 bolt main 350 into it, and did some pretty serious mods to it. I was friendly with the shop that handled anything I couldn't do (usually a lack of the appropriate tools). One day the owner pointed out that my firewall had cracked. Why? Because there was too much torque, and it had flexed the body too many times. The doors started not closing right which was the more obvious problem. So, we had the body straightened, and welded in a cage and subframe connectors.
Do you want to keep driving your car, or upgrade it until something major fails (like twisting the body beyond repair)? Right now, I'm very happy with my car. I can take uphill on-ramps like they're a straight flat road. If I need to pass on a 2 lane road, I'm past the car in front of me like I'm a blur rather than hanging out in the wrong lane. A few weeks ago, a guy in a heavily modified 4wd truck with a very obviously large turbo (it was screaming) wanted to play. I went 60 to 120 like he was standing still, and he laid off. I don't really *need* more power. I could put the NOS back on, but it's not worth it. The only thing I ever have to fill is my gasoline tank.
Not to say my advice will make anyone not put NOS on. They'll likely learn the same lessons I've learned. Buy a nice car (like our F-bodies) and enjoy it for what it is with just a few mods. Don't destroy it trying to make a car that can break land speed records. I guess most importantly is, no matter how much time and money you drop into *your* car, there's always someone else who has a bigger budget and a faster car.
05-16-2010, 04:44 PM #129
- Apr 2008
- Fairhope, Alabama
Black- 2002 Camaro SS SLP
HSW Plate Kit, jetted for a 100 shot was the BEST mod i ever did.
2002 Camaro SS A4 - SLP# 2951 l MS4 l LT's w/ORY l F.A.S.T 78 & TB l Borla l Cutout l CME l TCI 3500 l 3.23's l !emissions l !sway
02-20-2011, 06:30 PM #130
- Little Falls, NY
black- 2000 ws6
For me.... i thought 400 hp was really fast until I got beat by my buddies H&C z06. Now Im making 580 to the tires and pretty sure I wont have to worry about that again. I love nitrous
06-21-2011, 03:45 PM #131
BACK FROM THE DEAD FOR THE EMPTY NITROUS THREAD
09-08-2011, 11:00 PM #132
With all safety systems in place, what would happen if you are in a manuel and miss a shift. The rpm's would jump and the window switch would take over correct?
09-29-2011, 01:35 AM #133
Yes it will shut the n2o down. This is why a lot of people say window switch is a big plus for M6.
12-13-10 I was there
09-29-2011, 05:27 AM #134
- Aug 2007
- Texas
i just read most of this thread....I must have been confused
i thought nitrous was like a beautiful prostitute.....you really wanna hit it, but you're afraid of the consequences
10-05-2011, 11:34 PM #135
It’s like getting some awesome acceleration in couple of seconds which cost some money and also it’s dangerous.
10-13-2011, 11:24 AM #136
My car went from running a 7.90 in the 1/8th to a 7.12. Hell yea it's worth it!!
10-13-2011, 12:04 PM #137
10-13-2011, 12:12 PM #138
10-13-2011, 02:40 PM #139
10-13-2011, 04:32 PM #140
Just installed the zex perimeter plate kit for the first time , took about 6 hours. Two fifty - four dollars a pound for nitrous. When i sprayed it for the first time started with a 100 shot made a pass and pulled one plug and look to see where i was at as far fuel, you can tell by the tip of plug should look like a brown paper bag in color hope this helps
nitrous nozzle setup cheap and various size nitrous hoses
By RARON455 in forum Parts For Sale / TradeReplies: 3Last Post: 11-21-2011, 06:30 PM -
Nitrous newb have a question regarding Nitrous and MAFs.
By ForceFed in forum NitrousReplies: 16Last Post: 06-22-2008, 06:58 PM -
Direct Port Nitrous - Plumb Like A PRO - Nitrous Power!
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 01-24-2008, 06:30 PM -
Nitrous Oxide Systems - Say Yes To No - Nitrous Power!
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 01-05-2008, 01:00 AM
