Results 101 to 120 of 292
12-04-2010, 06:48 AM #101
12-14-2010, 04:25 PM #102
Been plinking away at the carb rebuild. Have everything cleaned up and ready to go. Two other issues were a busted throttle plate screw on the primary shaft and the secondary linkage broke when I bent it back into shape. I was able to center drill the broken screw and as I stepped up the drill bit size it released -- no harm to the threads. Phew!
In order to remove the primary shaft for installation of the bushing kit, I had to bend the rod for the secondaries to unhook it. Unfortunately, bending it out and then back in fatigued the metal and it snapped. I sourced a replacement rod from a Q-jet vendor that utilizes a clip to retain it -- no more bending.
Final clean up was performed with lacquer thinner and over 100 Q-tips. I'll use Eastwood's Carb Renew to make it pretty again before re-assembly.
12-15-2010, 03:44 AM #103
- Oct 2009
- The Woodlands/spring/houston
pewter- 99 trans am
so youre using the origional carb on a stroker? you modding the carb any? i didnt read the whole thread yet.
12-15-2010, 08:08 AM #104
12-15-2010, 06:16 PM #105
The fight with the Q-jet continued tonight. I started by installing the primary shaft with the new secondary linkage rod. Pretty slick setup that is identical to GM door handle and lock rods from the '60s and '70s.
I was hoping to get the main body and airhorn painted tonight. Instead, I ended up fighting with the seat that the fuel inlet needle rides in. It should simply unscrew, but instead decided to fight all the way out. I tried cutting a deeper notch with my die grinder, but still could not get it to break free. I ended up drilling it and installing an easy out that finally exerted enough force to back it out. I tore up the old seat, but at least the threads were left intact in the main body.
12-15-2010, 08:48 PM #106
Wow! The 2 un-like metals aluminum and brass, plus old varnish from leaded gas in the threads can make them interesting to break free.. Rebuild kits used to come with a "sealed" one piece float needle housing with a nut head machined into to the top.. Made life a whole lot easier being able to get a socket on them.. Hopefully you can get the damaged seat to seal.. If not it will leak fuel into the float bowl constantly as I'm sure you know. Cutting off the main flow control by forcing the float to hold the needle closed all the time..
Throttle plate looks good tho.. Looking forward to the finished toy..Last edited by Smittro; 12-16-2010 at 01:25 AM. Reason: corrections in spelling
12-16-2010, 03:06 AM #107
I will use a "blue thread paste" on the seat threads to ensure a good seal. The threads don't look terrible in the carb body despite the work it took to remove the seat.
12-16-2010, 03:53 AM #108
- Oct 2009
pewter- 99 trans am
come hell or high water, youre gonna use that carb, huh? i commend you, sir. most would have just given up and bought a new one.
12-16-2010, 08:23 AM #109
12-16-2010, 08:28 AM #110
12-16-2010, 08:40 AM #111
12-16-2010, 09:00 AM #112
It's comming along..
Gonna cut/prep header flanges prolly tonight or in the morning. Got the turbine inlet flanges and outlets ready. Then on to bending some 1-3/4 tubular steel for my header tubes. I'm going to use my trany as is and add an adaptor for the last 3 holes. The important holes between the quad bell and the LQ1 are a perfect match so it ends up not being the cluster I thought it would. Still have'nt desided on a clutch yet. Setup the PS pump in it's new location, and mount an electric water pump drive.. Have to finish milling my UI and bore out the fuel rails into the UI walls.. Then pull the front end off and prep for cleaning and painting under the hood.. Odds and ends mechanically after that. Then move to the interior. Have'nt settled on guages yet but I'm going full sweeps. The touch screen monitor handles the rest for AFR's and such..
- Sounds like alot but really it's not.. Suspensoin was replaced before she got parked so I'm good there.. I have everything else I need still in boxes so mostly just bolting stuff on and so forth.. I think I'm going to use the driver side heat vent in the hood as part of the CAI so some channeling there.. Little stuff you know..Last edited by Smittro; 12-17-2010 at 08:47 AM. Reason: added back original post
12-16-2010, 09:54 AM #113
12-16-2010, 05:58 PM #114
Just a few little things that want to be difficult. I enjoy a challenge, but right now I need to get this thing done and up to the builder so we can go play on the dyno.
Tonight I finished cleaning up the principle components and shot them with Eastwood's Carb Renew. While the first coat was drying I ran all the small parts that will be receiving a black oxide treatment through the wire wheel. If all goes well, I can start re-assembly tomorrow night and then get this thing in the mail next week.
12-16-2010, 07:02 PM #115
12-17-2010, 03:11 AM #116
40 years old to be exact. The exterior of the carb was pretty nice, but kind of mottled with age so I opted to refresh it. Someone had been there before as 2 or 3 of the screws had witness marks from being manhandled. I just dressed the edges with a small file and ran them on a wire wheel to blend them back in.
12-17-2010, 08:39 AM #117
- Aug 2010
- Oklahoma City, Oklahoma
sebring silver- Y2K SS CAMARO
[QUOTE=pajeff02;2517837]40 years old to be exact. The exterior of the carb was pretty nice, but kind of mottled with age so I opted to refresh it. Someone had been there before as 2 or 3 of the screws had witness marks from being manhandled. I just dressed the edges with a small file and ran them on a wire wheel to blend them back in.[/QUOTE]
going all out are we? you have got way more patience then i do brother i guess it just come with age
12-17-2010, 12:08 PM #118
12-17-2010, 12:11 PM #119
To most of you guys... I probably am considered "old".
12-17-2010, 12:26 PM #120
Question: anybody familiar with the oldsmobile aurora.
By dav-02ws6-m6 in forum General HelpReplies: 25Last Post: 07-03-2012, 02:44 AM -
I need some '69 Oldsmobile Cutlass parts! (help!)
By FasstChevys in forum Classic MuscleReplies: 5Last Post: 10-27-2011, 12:06 PM -
F/S or Trade 1970 SS396 El Camino Project
By H8tulooze in forum Vehicles For Sale / TradeReplies: 0Last Post: 09-01-2008, 06:42 AM -
Any oldsmobile forums?
By TARZAN in forum Almost Anything GoesReplies: 5Last Post: 05-31-2007, 02:59 AM -
1970 oldsmobile cutlass convertible forsale
By z-28lover in forum Vehicles For Sale / TradeReplies: 0Last Post: 10-25-2006, 10:32 AM
