Results 81 to 96 of 96
Thread: Headers on lowered car
04-22-2008, 05:39 AM #81
I lied, just got the full exhaust installed last night! I went pacesetter ceramics, and ORY with magnaflow catback 2 3.5in tips. OMG sounds so incredible. I am jealous of myself because I can't drive it. HELP
Reasons:
1. smoke coming from front of car, drivers side header. Do you think the header isn't flush?
2. it feels as if a plug wire is not connected the way it's running. I am quite sure what I feel is a piston not firing. Any way to tell which one it is?
3. My 02 sensors are not connected. Does this affect performance? I need to extend the wires.
04-22-2008, 05:40 AM #82
And oh yeah, the fitting is excellent, I mean excellent. Tucks up very well, passenger side header is low though, and I did scrape once in a very short ride, about 15 feet. Wow though, so worth it
04-22-2008, 07:45 AM #83
smoke is from the kind of a wax on the headers and your finger prints burning off... and ya you need the o2 extensions and to delete the rear o2's to drive properly
04-22-2008, 08:00 AM #84
I have Hooker LTs, they tuck like nothing else and my car is slammed too... you have to watch the Y-pipe, that is what you will scrape.
Like said before, avoid going straight over speed bumps and go into driveways almost paralell to them and you will be fine.
My city has the shittiest roads on the planet and i have yet to hit them on anything going down the road.
Another vote against SLP LT's... shops in my city wont even install them becuase they are such shit . SLP in general FTL
04-22-2008, 03:03 PM #85
A couple suggetions
Make sure the header bolts are tight, sorry obvious but they are hard to get to so easy to not torque the back ones down enough. Did you get new gaskets from GM or reuse the oldies? Pacesetter gaskets suck and they can leak.
You could also check the wires at the coil packs, they can get out of alignment when you push them on easier than the ones to the plugs
Yes you must have front o2s in place to run your car - it cannot get the air/fuel mix right until you have them. You can run ok w/o the rears.
Good luck and enjoy your new headers
04-24-2008, 06:54 PM #86
well well, header is snug, pretty sure my front 02 sensors are okay and still having a problem. Car seems like it is running possibly on one cylinder. when sitting and I rev the car up, it sounds alright. However, when moving it has no nuts at all and bogs. Thinking maybe a plug wire issue? I had a few previously. I mean it really has nothing to it. Any suggestions?
05-08-2008, 05:20 AM #87
Alright, I give up. Bringing it in to a shop I guess, I just can't figure it out.
05-08-2008, 08:29 AM #88
- Apr 2008
- Newport NJ
2002 Jeep Wrangler Sahara- Black 2002 Trans Am WS6
Hope they can straighten you out so you can see what those headers did for ya!
Black 02 Trans Am WS6 M6 SLP Lid, Bassani Stainless Headers & Y-Pipe w/o Cats, Borla Exhaust, BMR-STB, LCAs & Reloc. Brackets, Panhard Bar, & SFCs, Eibach Pro-kit With Bilsteins, BF Goodrich G Force KDWs, Optima Yellow Top, 5% Tint, Blackouts, Clear Side Lights, H-7 Headlights much more to come!
05-08-2008, 03:07 PM #89
Wow. No O2s is definitely a performance problem. Checking all the wires to be sure they're seated 100% and make sure all the plugs are installed tight. Sounds like you have a misfire problem for sure. Also, reading the plugs would start to tell you where its missing.
Hopefully the shop you took it to straightened you out.
-Eagle
05-15-2008, 06:58 PM #90
Well, I put in high flow cats (State requirement) and front/rear 02's. Seems to be real fast. I can beat my buddies C5 that has an exhaust, so I'm thinking I'm all set. Unfortunately I was testing her out today...Needless to say a ticket was in my future. Not good. I have a lead foot when I'm out with the C5 and the 350Z...
Anyway, the headers had to be cut a tiny bit to fit the high flows, but worked pretty good. Tuck is decent, but hangs below my sfc's and definitely sparks over bumps. I'd say there's about 2 inches from ground to Cat. Sounds awesome!
05-19-2008, 05:40 PM #91
- washington, dc area
Black- 2002 Firebird
I can attest to the low ground clearance on SLP headers. I had a set installed and need to be real careful going over speed bumps or I will rub.
07-04-2008, 09:05 PM #92
- Aug 2007
- Greeley,Co
Artic White- 1999 Z28 408 Stroker M6
Have QTP's on sportlines and never have scraped... But alot of it is avioding bad situations too....
99 Camaro Z28-
Colorado's Slowest 408 with a 150 shot
95 Camaro Z28 LT1-
LT4 Hot Cam Kit, Fuddle 3,800 Stall
http://www.fquick.com/99Ls1fever
07-05-2008, 08:45 PM #93
07-05-2008, 09:11 PM #94
Well they look like that because they are "tuned", so all the runners are equal length. It may add a little bit, but not worth the crappy fitment or low ground clearance.
I find it especially ridiculous how the SLP's are showing surface rust in that picture, nothing like using the cheapest (409) stainless on $900 headers
07-05-2008, 09:17 PM #95
Equal length headers dont mean shit when there bent to fuck like that for one. On top of it, they are (were?) using shitty ass steel. SLP is constantly making such a great name for themselves.
07-06-2008, 03:38 AM #96
- Aug 2007
- Greeley,Co
3rd grade welding project....
BEST for Traction? Lowered vs. Not Lowered
By MrMasterCraft in forum Suspension and HandlingReplies: 4Last Post: 02-12-2010, 09:19 AM -
02 ss lowered need help...
By camaroboy 14 02 ss in forum Camaro / SSReplies: 4Last Post: 08-31-2009, 05:45 PM -
Lowered with Sportlines, Headers?????? Anyone?
By Supermonkey147 in forum Camaro / SSReplies: 16Last Post: 08-08-2009, 06:56 PM -
which headers for a lowered vert 99
By NitrOmm in forum External EngineReplies: 21Last Post: 10-25-2008, 01:10 PM -
Ground Clearence Lowered Headers
By jmhvenom in forum External EngineReplies: 0Last Post: 03-01-2006, 08:40 AM
