Results 61 to 80 of 92
Thread: Ominous Glow Write-up
03-23-2009, 08:29 AM #61
- Oct 2007
- Connecticut
Red- 2000 Camaro SS M6
Alright, so I've got my LED's installed. Put some aluminum tape (the kind used for duct work) on the bottom face inside the scoop. Looks reeeeeal good. I'll post pics in a few days.
I'd like to wire them differenty, though, so I don't have to dim my dash lights when I want to dim the LED's (i.e. I don't want to get pulled over). I was thinking of wiring them to the Fog lights (where's the fuse for that?) Or maybe I'll do a basic on/off switch and stick it under the dash. Anyone know how either of these would work??? I don't know jack about electrical.
03-23-2009, 02:40 PM #62
nice job your ride looks good with it on it. there is a white ta in north ky whit blue in the hood and i like your install much more.
03-25-2009, 11:00 AM #63
I thought about doing the on/off switch as well, but like you I am not electrically enclined enough to know how to set it up. Connecting it to the dimmer has worked out great so far. I usually dim them during the morning ride to work just enough so I can see the dash..and then again at dusk when the daylights come on.
03-25-2009, 04:01 PM #64
- Oct 2007
- Connecticut
03-25-2009, 07:03 PM #65
- Jun 2008
- Orlando FL
Red+White Top and Stripes- 2000TransAmConvertible A4
It is not hard to wire a switch in, come on guys.
FAST 90/90, SLP Lid, Kooks JetHot Coated LT's, American Racing Y-Pipe+Magnaflow Cats, DHM Electric Cutout, Flowmaster American Thunder Catback, HP Tuners Software, 343 rwhp.
BMR Convertible Subframe Connectors, Hotchkis Strut Tower Brace, BMR Driveshaft Safety Loop.
03-26-2009, 05:12 AM #66
- Oct 2007
- Connecticut
I know it's not difficult. It's just that fear of going outside and seeing your car on fire that makes you think twice. Plus I want to make sure it's a clean, hidden look. I don't want to rice out my interior with aircraft switches.
03-26-2009, 05:18 AM #67
- Oct 2007
- Connecticut
Here's some images. I used a 9 inch LED strip with aluminum tape on the bottom face inside the scoop. I like the second one with the clouds in the background...
03-26-2009, 07:53 AM #68
03-26-2009, 08:44 AM #69
Yeah after thinking about I agree it is pretty simpl huh...funny you mention "fire" though. I noticed my dim switch panel being very warm this morning after the drive into work. I am curious if anyone noticed more heat than usual on thier panel. I never noticed before so this could be normal. We really don't want any fires here
03-26-2009, 08:48 AM #70
03-26-2009, 08:49 AM #71
- Oct 2007
- Connecticut
03-26-2009, 10:44 AM #72
03-26-2009, 01:10 PM #73
When I wired my neon, I wired them independantly from the lights. I grounded the neon to the chassis, and ran the hot wire through the firewall to the back of the console. I then tapped into the cigarette lighter next to the ABS switch to power them, and followed the directions included on the lighted switch.
For the switch itself, I hooked up the hot wire from the neon to the switch, then ran wire from the the cigarette lighter's hot wire (researched online to determine the hot wire....don't remember which one it was now though) to the switch, and finally a ground wire from the switch to bare metal.
I threaded the wires through the cigarette lighter's housing and put the round lighted switch in there. I can turn the lights on and off whenever I want.
03-26-2009, 02:29 PM #74
03-26-2009, 02:37 PM #75
I have them in a plastic wire loom, taped to the underside. I used clear packing-type tape, and a black loom and it's held for over 3 years. Doesn't look crappy as I pulled it tight, and only used a couple pieces to hold it secure. I tried different things, and ironically, the packing tape worked best. I tried electrical tape and a sort of sticky back clip, neither of which held secure enough. I didn't want the wires to fall into the engine...
I suppose I could've used double sided 3M tape on the back side of the loom and tacked it up that way too...if it ever falls, I might try that....
I ran them down the passenger side, and in through the whole that's already on that side of the firewall...
03-26-2009, 02:40 PM #76
03-27-2009, 11:01 AM #77
03-27-2009, 11:10 AM #78
Thanks...it probably only took me an hour or so, at most...the hardest part was getting them through the firewall. Had to unbolt the computer and move it out of the way to access the hole easier.
I'm sure a dimmer would work. I have mine on a regular on/off switch. It's off 99.9% of the time. I usually only turn them on when I'm sitting in a parking lot, getting gas, or if someone cuts me off. I'll flip them on for a second, then turn them back off. Almost never have them on when I'm on the streets
The cops in my area don't play around, so I try not to give them an excuse to pull me over. They do a fine job of thinking up things to get me with all on their own anyway....
03-27-2009, 11:34 AM #79
Ok, thnks. I will probably put a dimmer in when I do the wire relocation mod and the autotrix passanger window fix. I have to move the computer then anyway. So far I have passed about a dozen cops and about 3 or 4 looked pretty hard. So, hopefully they feel that they have better things to do than stop me for that.
04-02-2009, 03:18 PM #80
- Feb 2006
- U. S And A Greatest country in all of world
Stock- 2002 Camaro
i want to get one that goes back and froth like kit!
reverse glow gauges?
By ls1ws6ben in forum General HelpReplies: 5Last Post: 10-14-2011, 03:37 PM -
led / reverse glow done !!
By barryz in forum Appearance SectionReplies: 11Last Post: 12-02-2010, 05:58 AM -
el reverse glow gauges fit?
By barryz in forum Stereo and ElectronicsReplies: 1Last Post: 01-15-2010, 02:04 PM -
reverse glow gauges
By barryz in forum Appearance SectionReplies: 3Last Post: 03-25-2009, 06:22 AM -
Ominous blue glow
By MaxPlusTen in forum Appearance SectionReplies: 65Last Post: 03-02-2009, 07:25 AM
