Results 61 to 79 of 79
Thread: 1997 RS vs. 1986 Iroc-Z
06-26-2007, 10:44 AM #61
- Jan 2007
- Rockford, IL
Silver- 2000 Camaro SS
yea i thought there never was a 5speed lt1? i heard they couldnt handle the amount of torque
06-26-2007, 10:51 AM #62
06-26-2007, 01:43 PM #63
the only two options are im either mistaken, or im lying.
he had the sticker/option list/documentation or whatever u want to call it, so im sure im not mistaken.
and flat out lying would be pretty retarded and would give me o satasfaction at all.
so well just leave it at that. im sure i could find a better way to prove it, but its not worth the effort.
06-26-2007, 01:45 PM #64
06-26-2007, 02:52 PM #65
- Jan 2007
- Knoxville, TN
B2300 (Fluffy) Retired- Plain-Jane Dodge Truck
You're not lying, your not wrong, so there's our proof. Do you believe things you read on the internet, even if everything else we can find says it is NOT available?
Sorry charlie....another baseless internet rumor, IMHO. Provide evidence to the contrary, and I'll be the first to come here and apologize and tell you I was wrong.
Bob
06-26-2007, 05:26 PM #66
06-26-2007, 07:59 PM #67
06-27-2007, 04:11 AM #68
Comparing the auto to the manual is not apples to apples. They stick the weak autos in these cars because to put it simply,,,,the autos will not incorporate the drivetrain shock the manuals can inflict. The 700r4 that is the predocessor to the 4l60E is also weak in stock form,,,but it survives as well. You simply put them in gear and go, no driveline shock, no banging shifts, they are designed to be easy on themselves from the beginning.
The manuals on the other hand (the weak 5 speed in particular) is more in the driver hands, and can be abused anyway they see fit,,,popping clutches, slamming gears,,,all this stuff is very hard on the transmission,,,,which is why they were never installed behind anything larger than a 305. They just cannot handle the torque capability of the 350 TPI or the 350 LT1, the trans would simply take itself apart.
Comparing durability in manual transmissions to auto transmissions is so far out of wack I can't even put it into words. They are on 2 completely different playing fields.
06-27-2007, 07:36 AM #69
but see, the thing is, they did put the 5 speed behind an LT1. and rather than mee prove it to u, how bout u prove me wrong. u do that then well talk more.
06-27-2007, 08:30 AM #70
- Jan 2007
- Knoxville, TN
Really? Ok, let's look at this logically. You say you know a 5-speed was available, because a buddy had one with all the documentation, yada yada yada. You can show us nothing - only tell us this on an internet forum.
Everybody else says that the only manual tranny available for the 93+ Z28/Formula/TA is a T56 6-Speed. A simple search or three will show this conclusively. For example:
An Edmunds Write-up. Note where the article states "Behind it was either a four-speed automatic or six-speed manual transmission."
Details of the 1993 Camaro, including tranny options near the bottom of the page. Also, note the full options page. I didn't see a 5-speed tranny as an option. Perhaps you can find it for us?
Here's the same thing for 94. You can also find 95, 96, etc via links on that page. Thinking logically, one would reason that if a 5-Speed was available with the LT1, it would be mentioned somewhere in there. Don't you think?
From cargurus.com, specs on the 94 Camaro. Note where it has an "N/A" under the Z28 column in the 5-speed line, and where it has "STD" for the 6-speed. Note also that if the 5-speed had been an option, it would have had "OPT" instead of "N/A". As in the above links, the same thing is also available for other years.
From the F-body.org 4th Gen General FAQ page, and from the related F-body.org 4th Gen Drivetrain FAQ page...only 6 speeds. Of course, as I'm sure you know, the 93 had a different version(s), but it was still a T56, and still had 6 gears.
Now let's consider all of this 'logically'.
You say there were some factory 5-Speed LT1s, yet you have no documentation to back this up.
Everybody else here says there was no such thing, and above is just SOME of the documentation to back that up.
What does 'logic' dictate? That's a pretty easy one - you are wrong.
Personally, I think you were looking at a V6 car (which did indeed have a T5), and now just don't want to admit being wrong. However, given the benefit of the doubt, I've presented my proof - that anybody here can check out for themselves - that there was no such thing as a Factory LT1 with a 5-speed transmission. Now it is your turn to "talk", as you put it.
'Put up or shut up', I believe is the operative phrase here.
Bob
06-27-2007, 04:25 PM #71
- Jan 2007
- Rockford, IL
this thread will get locked soon if this goes on...
drew, no offense, but its much easier to prove that something is true than to prove something ISNT true. im not pickin sides here, im just sayin maybe u should post up some RPO codes or w.e... all the info on the net so far points to the fact that there wasnt any 5speed trannys for lt1's.
its not that i dont believe u, its just going to take SOMETHING to get me to believe it.
06-27-2007, 04:29 PM #72
yeah, i thought this was settled back on 5/28. i'll give it until the end of the night for him to present any internet proof. then, it's locked.
06-27-2007, 04:34 PM #73
06-27-2007, 05:26 PM #74
- Jan 2007
- Knoxville, TN
As previously stated, present the evidence that I'm wrong, and I'll be the first to apologize/admit it.
Bob
06-27-2007, 08:16 PM #75
06-28-2007, 09:57 AM #76
- Jan 2007
- Knoxville, TN
chirp
chirp
chirp
06-28-2007, 11:48 AM #77
i was just trying to share a bit of interesting information on a rarity (5 speed in a lt1). not start an argument. but u all want to get on here and act like ****** (insert ur own word i dont feel like getting another warning) and say u dont believe me.
i just talked to my friend. like i said befor it was a special order. that means u tell the dealership every specific option u want and they get u one, not a one off from some custom shop or some crap like that, u can do that at any dealership u want when u buy a new car. its not a strange thing.
of course its not going to be on these option lists ur looking up on the net. it wasnt a standard option. so thats no proof to me at all.
but ill give u the same courtesy, u prove me wrong and ill apoligise. but seing is thats not possible, i wont have to worry about it. ive personally seen a 95 lt1 camaro with a 5speed. u on the other hand have not seen every 95 camaro in existence and can not say that none of them had 5speeds. thats logic
so all u can do is flat out call me a liar... and this i dont apprechiate
and i found out his perticular car still exists. it was totaled but a guy in gowling green kentucky bought it and rebuilt it. its a 95 z28
and no im not going to go find it and show u... but ur welcome to take a trip down there and look it up... i believe its red (but he had to repaint it so it could be any color now)
so put up or shut up urselfe...
dont bother responding caus i wont respond to this thread anymore. ive said enough and have no need to convince anyone any further.
go ahead and lock it fellas
06-28-2007, 03:03 PM #78
- Jan 2007
- Knoxville, TN
It's not a rarity - it's a falicy. When you post such falicies on an interent message forum without any evidence (at all) to back it up, you should expect to be called on it. That's the internet, you would be wise to get used to it.
I don't think you're lying, I just think you're wrong. I provided you plenty of proof - far more than just "my buddy has...err...had one". You chose to ignore it. Guess that's up to you.
"Special Order" (which is a misnomer in and of itself) would still have to be ordered from the factory (as you implied). In order to do this, there would have to be an RPO code. One of the links above had all the RPOs that were available for each year the LT1 was available. None of them listed an 5-speed for an LT1 car. As such, there is ample proof that a 5-speed was not available. Once again, you choose to ignore this.
I have little doubt you would want this thread locked. If I were in your shoes, I'd want out of it as soon as possible too.
Have a great day!
Bob
06-28-2007, 03:05 PM #79
ok we are done.
LSX 1986 Camaro
By 1nasty86 in forum LSx Retrofit and SwapReplies: 4Last Post: 08-10-2012, 07:28 PM -
Gauging Interest: 1986 Chevrolet Camaro IROC-Z
By 86 IROC-Z in forum Vehicles For Sale / TradeReplies: 0Last Post: 04-27-2008, 09:25 PM -
1986 Iroc
By Larsen89 in forum General HelpReplies: 1Last Post: 03-07-2006, 06:48 AM
