Page 3 of 6 FirstFirst 123456 LastLast
Results 41 to 60 of 111
Thread: cam too big?
  1. #41
    Member chevyss1234's Avatar
    Feb 2007
    Clemson SC
    m'kay i'll call texas speed and see what they can do
    by the way i read that too about them failing, but i also read the problem was corrected, do you think that -with the failing issue aside- they're good springs to run because the dual springs are $100 more
  2. #42
    $100 more, but they come with new seals, retainers, guides, everything.
    GM LS Series Patriot Gold Dual Valve Spring Kit Includes Patriot Gold Springs, Super 7 Locks,Titanium retainers,Seals,& .505 OR .565 Bases
    http://www.lmperformance.com/5031/1.html
  3. #43
    Feb 2007
    Clemson SC
    do they fit in where the stock sized spring was? is it harder on the other parts and motor in general to run these stronger springs?
  4. #44
    Quote Originally Posted by chevyss1234 View Post
    Not really.
    Spring rate is a little heavier, but not much.
    And yes, those fit stock heads.
  5. #45
    Feb 2007
    Clemson SC
    is it harder to install new retainers and what not rather than just the spring.. dumb question i know but...
  6. #46
    Retainers have to be installed either way. Old or new.
  7. #47
    Feb 2007
    Clemson SC
    yeah the guy at texas speed also pointed out to me that the springs last longer than the comp 918's as well, which convinced me to do it.
  8. #48
    Member raysz28's Avatar
    Central Ohio
    Ticket Red
    M6 1998 Z-28
    so what all did you end up ordering??
    i was thinking of just getting the LS6 springs.
    Also, how do you decide what length to go to on the rods? i have heard that when you go more agressive on the lift, the length needs change too. but which direction?
  9. #49
    Feb 2007
    Clemson SC
    i got a tsp 228r cam with patriot dual springs and texas speed hardened pushrods stock size
  10. #50
    Central Ohio
    Ticket Red
    M6 1998 Z-28
    i know the 112 vs. 114 LSA TSP 228R cam may give a little more low end power, but are there any drivability issues verse performance gains? but, does it REALLY matter between the two?
    i really like the sound clips i have heard of this cam! and it seams to have impressive gains.
  11. #51
    Feb 2007
    Clemson SC
    yeah as far as driveabiltiy issues i've ridden in a 112ish car and it really wasn't that bad, granted i'm a 20 year old kid and i couldn't care less if the car has a/c... cuz it broke a while back lol... from what it seems like though, this is a pretty streetable cam regardless of lsa, from what i've read,
    but no, i don't think it's THAT much of a difference at all but i'm no expert
  12. #52
    Quote Originally Posted by raysz28 View Post
    LS6 springs are only good to .550" lift.
    Honestly, probably a wasted swap.
    The things that change the pushrod length...
    Lifter preload.
    Heads milled.
    Base circle of the new cam.
    Block got decked.
    Rocker pedestal height.
    There are several other things as well, but those are the more common.
    One should always use a checker to be sure anyways though.
  13. #53
    Approver of Threads SpecterGT260's Avatar
    Iowa
    Blacked out
    '98 Trans Am
    i was told by tsp to use stock length rods on my 595/598 lift cam.
  14. #54
    rapter34
    Guest
    wondering the same thing what are the big differences between LSA's
  15. #55
    Central Ohio
    Ticket Red
    M6 1998 Z-28
    Quote Originally Posted by SpecterGT260 View Post
    how did stock length work out for you? did you change springs too?
    98 Ticket Red Z28
    Mods:
    Front/rear sway bars, poly bushings all around, Bilstein Shocks, Centerforce Dual Friction Clutch, Pacesetter LT's, 2.5" Custom True Duals over the axle with Magnaflow mufflers, Shortened Pro 5.0 shifter, TurnOne PS pump.
  16. #56
    You HAVE to change the valvesprings if you install ANY cam (aside from a new stocker).
    The stock valvesprings barely handle the stock cam.
    Verify pushrod length with a length checker.
    Most aftermarket cams are a touch smaller on the base circle. Which means a touch longer on the pushrod would be a good thing.
    Stock 7.400" pushrods may make a touch of noise with same cams, as they are a hair too short.
    7.412" would be about perfect....but those are a custom made pushrod.
  17. #57
    Feb 2007
    Clemson SC
    okay so just to be sure i got the 7.400 pushrods as reccomended, that's what i should have gotten correct?
  18. #58
  19. #59
    Feb 2007
    Clemson SC
    sweet.... dude i can't wait for this stuff to get here!
    and thanks again for all the help
  20. #60
    Iowa
    Blacked out
    '98 Trans Am
    worked fine. i used patriot double gold springs (to .650 lift) with their own seats, seals, locks, and retainers.
    made 385/370 at the dyno last weekend. the clutch is slipping like a sonovabitch too, so while torque was measured, rpm was over 1000 off screwing with the hp calculation. so actually there is more torque to be had, and a good bit more power after a clutch swap.
    this was on a loaded land&sea dyno, similar to a mustang dyno. the cam is a tsp tqV.2 232/234 595/598 113lsa+1
