Results 41 to 60 of 68
Thread: 4l60E
05-08-2009, 11:17 AM #41
05-23-2009, 04:08 PM #42
- Sep 2008
- Atlanta, GA,Ft.Walton Bch,FL
- Blog Entries
- 1
silver- 99 ws6
05-23-2009, 05:24 PM #43
Yes it's a 6 speed auto
05-24-2009, 02:59 AM #44
The weak points of the 4l60e is the clutch basket and valve body plate. Put a Beast sunshell ( basket ) and a transgo plate in, she'll last !
I'm still running the original 4l60e in my 98 with a 4600 stall, launching it hard every time. Plus, it's programmed where to shift, so I leave it ion OD down the track.
05-25-2009, 07:42 AM #45
05-25-2009, 08:16 AM #46
05-25-2009, 11:23 AM #47
- May 2009
- CT
They seem to be hit or miss, some blow up with stock power while others are running in the 10's on a stock tranny. I put on a good cooler, deep pan and keep the fluid fresh, hopefully it lasts.
05-25-2009, 12:47 PM #48
05-25-2009, 04:21 PM #49
- Nov 2008
- harrisburg pa.
black- 02 vette vert
05-26-2009, 09:18 AM #50
- Jan 2006
- Shepherd, Michigan
well i have to disagree ..everything i have ever seen about the 4l60e says otherwise
here
here
"The 4L60-E derives its designation from its specifications: 4-speeds, Longitudinally positioned, 6000 lbs. GVW, Electronically controlled, although the transmission sees factory service in trucks up to 8600 lbs. "
"Believe it or not, "4L60E" actually does stand for the specifications of the trans and isn't just General Motors trying to mess with us-4L60E stands for four speeds, longitudinally positioned, 6,000-pound GVW, and electronically controlled. When the 4L60E transmission was phased into production, the 700R4 was renamed 4L60. Notice the missing "E" for non-electronic."
plus GM rated the 4L60-E is to handle up to 360 ft·lbf of torque..
plus dont transmissions always get rated for torque and not horsepower ?
05-27-2009, 05:19 PM #51
06-25-2009, 05:40 PM #52
So shifting a 4l60e is a really bad idea? i sure hope it isnt becuase i do (for some reason or another) shift it manually when i am, at the strip, autocrossing, and just daily driving. I havent had any problems with it yet considering the motor has seen around 6k under a manual shift and it did well and didnt sound to hurt it at all. But if this could be a problem that can get worse i will definatly stop my strange habit
06-25-2009, 06:57 PM #53
Most won't shift manually at WOT. Do you have a shift kit in yours ?
I program my shift points & leave it in OD at the track. Very consistant !!!
06-25-2009, 08:01 PM #54
no i do not have a shift kit, but the transmission shift is VERY responsive and harly no delay, a buddy of my with a t56 and an lt1 said that my car shifts into gear faster than he could with a manual. mayb ive got a 1 off miracle auto. My 1st to 2nd is almost perfect weather its @ 2k or 6k but my 2nd to 3rd is perfect @ 6k but slightly delayed at 2k but i think thats because the tranny is checking my make sure its able to go into gear with out bogging down... u know how "smart" these trans are... hopefully im not seriously fukin something up by doing this
06-26-2009, 06:52 PM #55
Once I added a lot of power adders, that's when I had to lower my shift point programming. It would over shoot the shifts and hit the rev limiter. Mine never did shift manually... It would bounce the limiter...
As long as yours is shifting, it will be OK !!!
Have you had it to a track to see what times it's running ?
06-26-2009, 06:58 PM #56
Well When im in neutral or park my limiter is at 6,200 (I THINK) but when im in Drive/OD and mash it 0-60 (1st gear) it shifts at about 5,500 every time which is like 55-58 mph, but when i do it myself i can wind it all the way up around 6,000 and ive seen the speedo at around 61-63 in first gear, u may think im lieing but some of my buddys have seen it an been like, "holy fuck u can go 0-60 in first gear", and i end up just blowing by manuals while they are shifting at around 45
I remember when i raced a buddy of mine who has a lt1 t56 and when we launched i put like 2 car lengths on him and then he reeled me back in to almost within a car but then he had to shift at i think he said 45, and while that was all happening i easily put 5-6 carlengths on himLast edited by 64MonGooSe64; 06-26-2009 at 07:04 PM.
06-26-2009, 07:51 PM #57
06-27-2009, 04:09 AM #58
- Sep 2008
- Blog Entries
- 1
silver- 99 ws6
3rd
when cruiseing around town I always have it in 3rd.
have been told this will limit the auto. from shifting like in 35mph traffic that will speed up a little then slow down if it;s left in 3rd it will stay in 3rd.
I leave it in 3rd entering the expressway and getting into my left lane spot, then shift to OD around 75-85+MPH
the more shifting = more wear.
Someone correct me if I'm wronge on the 3rd theory.
plus you take off quicker in 3rd & the exhaust sounds cooler in 3rd which is usally 500RPM higher than OD.Last edited by qwik219d9; 06-27-2009 at 04:12 AM.
06-27-2009, 06:15 AM #59
Tranny sucks
I have had mine blow 3 times and the car only has 43K miles. The first was understandable since all the work I have done. But the next two times is rediculous. If it happens again Im going out and buying a better tranny to put in.
06-27-2009, 07:41 AM #60
which 4l60e's are the same as 02 lsx......
By jsmith564` in forum Automatic TransmissionReplies: 1Last Post: 07-06-2011, 06:30 PM -
Need a 4l60e 98-02
By ROMERO98Z28 in forum Parts Wanted / TradeReplies: 1Last Post: 05-10-2011, 05:07 PM -
wtb lt1 4l60e..
By pr0zac in forum Parts Wanted / TradeReplies: 0Last Post: 11-16-2006, 01:49 PM -
'95 4L60E vs '01 4L60E biggest difference?
By kgrantkey in forum Automatic TransmissionReplies: 9Last Post: 04-28-2006, 12:09 AM -
LT1 Motor, LT1 4L60E, & LS1 4L60E
By buck6680 in forum Parts For Sale / TradeReplies: 6Last Post: 09-05-2005, 07:41 PM
