Results 41 to 60 of 63
Thread: Weight reduction wiring
03-25-2011, 04:26 AM #41
I see you are in Philadelphia its a short trip. I am right next to Lansdale.
1) Yes a/c is removed. I did remove heat but I meant to do that. It is very simple to retain heat and remove a/c though. I am going with a hot rod heater. it's about 275 for the setup tiny and easy to install. Lighter than keeping the stock setup too.
2)Wipers.....lol I haven't even touched them yet. The car will be at the track before I hit the street. But I have found a bunch of simple universal wipers. I will make up a bracket and mount it in the stock location for the driver side. I can not run the passenger one b/c my intake fills that spot up
3)buy this POW!
http://www.summitracing.com/parts/sum-g1472/
4)AIR system was removed 3 years ago and yes its tuned out.
5)Yes for rear defroster. I will go with a lexan rear window so no defrost and its lighter.
6)coming right off the seatbelt latch next to the center console. There 2 black wires.
03-25-2011, 05:02 AM #42
02 Sweet, does that company make those with provisions for an intercooler?
03-25-2011, 05:07 AM #43
Yes they make them custom however you want them. You can get them setup for intercooler, rad and pump, fuel cell, etc...
It's nhra approved to hold fuel per how thick the chromemoly is. It's less than 10 lbs.
I choose to get mine stock off the shelf. When I get to the point I need to mount something in there I can grind it down and weld what I need on.
03-25-2011, 05:14 AM #44
03-25-2011, 03:33 PM #45
Well I guess I got a little crazy with the cutting. Before I put the interior back in I figured I would try and start the car. Well it started right up but the starter kept spinning! I have some work ahead of me.
I knew I would catch a snag on startup but I figured it WOULDN'T start.
03-25-2011, 06:48 PM #46
03-26-2011, 05:53 AM #47
03-26-2011, 07:33 AM #48
03-26-2011, 09:32 AM #49
03-26-2011, 10:24 AM #50
03-27-2011, 06:39 AM #51
Thanks me too!
UPDATE!!!
So before I decided to start putting the wire mess back together I figured I would test all of the things I WANTED to keep.
Surprisingly everything still works!!!
Last night I wire loomed and taped all the wires back together. I also reinstalled the dash brace as well. I ended up stopping there to running out of kerosene.
Today (as soon as the damn garage warms up its still 45 in there) I will be removing the antenna bracket, amps, speakers, and other random things. I am still up in the air about cutting out the rear seat brackets just in case.
03-27-2011, 06:41 AM #52
What is your goal for a final weight?
03-27-2011, 06:44 AM #53
03-27-2011, 07:44 AM #54
03-29-2011, 07:40 AM #55
- Oct 2009
- pasadena md
- Blog Entries
- 2
Black- 2002 SS Camaro
What rims are you going to go with an are you changing out the driveshaft?
2002 Camaro SS Black Betty
Suspension:
Poly Trans mount, Solid Motor mount, Strut tower Brace
Performance:
SLP intake, Smooth Bellow, A.I.R Delete, M/T's on Salad Shooters
Apperance:
Re-Badged, Ultragauge, Whistler Mod, Racing Seats, Auto Hurst Shift Handle
03-29-2011, 07:56 AM #56
03-31-2011, 04:35 AM #57
- Oct 2009
- pasadena md
- Blog Entries
- 2
Which drive shaft are you looking at I can only find this one, I've been debating buying one
http://www.lmperformance.com/1565/1.html
03-31-2011, 05:00 AM #58
04-01-2011, 08:32 AM #59
- Nov 1999
- over here...
damn... now i got to do a weight reduction on mine...
04-01-2011, 08:33 AM #60
- Nov 1999
- over here...
3260 with out me in mine and a 1/2 tank of gas... right around 3450 with me in it... i think i'll do a weight reduction on my self... get down to the 160lbs i was in jr high...
Weight reduction
By jetaws6 in forum Drag RacingReplies: 4Last Post: 08-13-2010, 03:19 PM -
Weight Reduction
By Bouvers in forum General HelpReplies: 10Last Post: 09-04-2008, 10:53 PM -
weight reduction
By picklejuice in forum Firebird / WS6Replies: 15Last Post: 08-20-2007, 01:28 PM -
weight reduction
By silverz28camaro in forum Drag RacingReplies: 7Last Post: 04-30-2007, 08:07 PM -
weight reduction
By senior gomez in forum Firebird / WS6Replies: 8Last Post: 01-22-2006, 01:59 PM
