Results 41 to 60 of 68
02-25-2009, 04:39 PM #41
02-28-2009, 10:33 AM #42
i just change mine out from season to season. I do beleive that it can run "to cold" in the winter to burn up the comdensation. i can take my oil cap off and it will have some water drops on the inside of. Just put the 160 in it for the summar months and stock in it for the winter months. btw i live in south carolina and do have a tune. i had a SLP fan switch on my lt1 z28 and loved it with my 160 stat.
02-28-2009, 12:50 PM #43
02-28-2009, 02:17 PM #44
03-03-2009, 04:32 AM #45
You are correct, the PCM will read the engine as not being warm, and you will be using more gas, with the A/F ratio richer to compensate.
I use a 180F thermostat, and have my fans adjusted for that (through the PCM), and the engine stays cooler, however that temperature is warm enough not to trick the PCM into thinking it is cold.
SteveC
03-04-2009, 09:29 AM #46
04-01-2009, 09:01 AM #47
i have a 180 and i runs good runs a hair under the 1/2 way mark on the tach but i havent set my fans yet
04-01-2009, 09:36 AM #48
04-01-2009, 09:49 AM #49
Ya I have the 160 t-stat and get killer mileage.
22-23mpg city/hwy - Best was 26.6mpg (A4 w/ 3.73's)00 Z28 M6 T-tops
00 SS A4 T-tops (Sold)
99 Corvette M6 (Sold)
98 Z28 A4 Coupe (Sold)
98 Z28 A4 T-tops (Sold)
04-02-2009, 04:19 AM #50
- Sep 2008
- Atlanta, GA,Ft.Walton Bch,FL
- Blog Entries
- 1
silver- 99 ws6
cooler not better
the LS1 makes bigger power when warmer it has been proven on the dyno cool motor verues warm.
I have the stock thremostate for this reason however I have lowered both fan settings.
also I like to crank and go w/ a cooler thremostate it will take longer for the car to warm up.cam-LTs-FAST78-Susp.-Rims
04-02-2009, 04:26 AM #51
04-02-2009, 08:54 AM #52
Car warms up just as fast,,,only difference is it stops warming up at a lower temperature,,,of which is not harmfull to the motor at all.
I'd like to see this warmer engine making more power than a cooler engine. Maybe on an engine dyno (out of the car in controlled conditions) it's possible but what you have to take into account is day to day driving and severe heat soaking. Once anything in the air intake track (including the intake manifold itself) is heat soaked it kills power.
Remember that every 10 degree drop in air intake temperature is worth 1% increase in Horsepower. This ratio increase the more the engine makes. That includes not only sucking in outside ambient temps but also you have to take into account the air intake duct work sitting right on top of the radiator as well as the intake manifold itself.
Even if the outside air is cool,,,,it is still heated as it passes through all this stuff. In regular driving conditions (especially in the hot south west) it becomes a real issue.
04-26-2010, 07:53 PM #53
So can you just get by with buying the 160 thermostat and not havning to tune the PCM???
04-26-2010, 07:59 PM #54
04-27-2010, 01:06 AM #55
- Jan 2010
- texas
silver- 2000 formula
i have a 160...........no tune.....and unless i have the a/c on i never hear the fans kick in....guess my system is just that efficent
04-27-2010, 04:50 AM #56
04-27-2010, 05:04 PM #57
- Apr 2008
- Madison, WI
The stock tune has the low speed fans come on at something like 222 degrees...so you may not hear them come on often.
04-27-2010, 08:02 PM #58
- Mar 2007
- Harmony NC
Pewter- 2000 Z28
Where did you get your 160 thermostat. I checked all the auto parts near me and none could find a 160 thermostat. O'reilly finally found and ordered me one and went to install it but didnt fit.
04-27-2010, 08:41 PM #59
- Jan 2010
- texas
you need to get one WITH the housing..........hypertech........slp
04-27-2010, 08:45 PM #60
- Mar 2007
- Harmony NC
Pewter- 2000 Z28
The one from O'reilly had the housing but wouldn't go in the block. The thermo was to wide to go in the outlet.
160 Degree Thermostat
By Anthracis in forum Internal EngineReplies: 30Last Post: 05-09-2007, 02:56 AM -
thermostat 160 degree
By joker in forum Firebird / WS6Replies: 7Last Post: 05-07-2006, 11:55 PM -
160 degree thermostat
By joker in forum Firebird / WS6Replies: 0Last Post: 05-03-2006, 04:41 PM -
By lonewolf37 in forum External EngineReplies: 7Last Post: 04-29-2006, 04:48 PM -
160 degree thermostat?
By 1fastredbird in forum External EngineReplies: 2Last Post: 11-13-2005, 03:49 PM
