Results 21 to 36 of 36
10-28-2011, 03:49 AM #21
- Nov 2005
- Royal Oak, Michigan
Black- 2004 GTO A4
10-28-2011, 05:29 AM #22
10-29-2011, 04:14 PM #23
Did the same thing when I had the ignition lock snafu (the first time). Got some channel locks and said fuck it's going to turn or break. It turned finally. At least the keys are pretty stout
11-08-2011, 10:21 AM #24
- Nov 2005
Black- 2004 GTO A4
Now I need to figure out why the alarm keeps being activated by the hood. The other thing is that now my auto headlights will not shut off and my fog lights won't work. Did I fry something?
11-09-2011, 06:03 PM #25
- Jan 2009
- North Jersey
If you adjusted the hood, and the alarm still sounds, and your lights are acting funky, sounds like the BCM is malfunctioning.
11-10-2011, 06:05 AM #26
- Nov 2005
Black- 2004 GTO A4
I will look into that. Thanks! BTW - I love your rims. What brand/size are they? I am also thinking about throwing on a heads/cam package on my 04. The issue is that I have the A4, so I would need a new torque converter with a higher stall. That just adds to the cost
11-12-2011, 04:36 PM #27
- Jan 2009
- North Jersey
Thanx. They are Stern ST-1 in hyperblack. 18x8.5 front and 18x9.5 rear. 35mm backspacing in front and 38 in back.
11-14-2011, 04:31 AM #28
- Nov 2005
Black- 2004 GTO A4
11-14-2011, 07:11 PM #29
11-14-2011, 11:34 PM #30
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
wow i never thought this could be the problem!
few says ago i disconnected the battery on my car cuz i was going out of town, when i got back i find out i couldnt open the door with the keY, i thought some one messed up with and broke it or some thing.. i had to get in fro, the back.. when i connected the battery the problem was one..
.lol..
11-15-2011, 04:54 AM #31
- Nov 2005
Black- 2004 GTO A4
Every once and a while, my temp gage peggs itself for no apparent reason, then goes back to normal. Sometimes the radio gets really loud, then goes back to normal a second or two later. Sometimes my dome light works, sometimes it doesn't. Now my auto lights do not shut off EVER. I sure hope all of this is due to bare wires and is an easy fix....if not, ?????
11-18-2011, 06:00 PM #32
- Jan 2009
- North Jersey
There is a TSB on the temp gauge as well as the fuel gauge not reaching "full" when you refuel. I believe you have to remove the correllating fuse for a few seconds and turn the car to "ON" without the engine running and I "THINK" it will reset the gauge cluster. As for the dome lights and auto lights, your BCM might be on the fritz and need to either be reprogrammed or replaced. A case relearn with a Tech2 scanner should help. Too bad only GM dealerships have those scanners.
12-05-2011, 07:45 PM #33
hey guys i hv an 06 and hv had battery issues but i simply put the key in and the door unlocks. The stupid thing is I can not unlock the driver side door with the remote. The remote only opens the passenger side. WTF. There is a post I saw on how to correct this type of problems But I can't find it.
12-06-2011, 05:49 PM #34
- Jan 2009
- North Jersey
I am thinking you may have a BCM issue. Possibly a partial short.
12-06-2011, 11:07 PM #35
Just came back to this thread to see how it was going.
Some time ago, we used to open door locks with a tennis ball.
I think it's even on you tube.
Drill a dime size hole in one, place the drilled hole over the key hole and press the tennis ball fast hand hard.
It does actually open the lock.Be who you are and say what you feel 'cause people who mind don't matter, and people who matter don't mind.'
-Nowhereman
12-09-2011, 12:31 PM #36
- Jan 2009
- North Jersey
I have never heard of that.
Help: Dead Battery
By 35th-ANV-SS in forum General HelpReplies: 30Last Post: 03-29-2011, 06:53 PM -
Dead Battery
By j nix in forum Stereo and ElectronicsReplies: 6Last Post: 01-15-2011, 08:02 AM -
Question: dead battery
By slimss in forum General HelpReplies: 7Last Post: 09-11-2010, 01:54 PM -
Help: Battery Dead..can't start
By molecularmann in forum General HelpReplies: 6Last Post: 08-10-2010, 06:56 PM -
Trunk, dead battery.
By INeedLS1 in forum Firebird / WS6Replies: 3Last Post: 06-19-2009, 02:03 PM
