Results 21 to 40 of 141
Thread: LS6 valley cover in pics
10-03-2010, 09:02 PM #21
- Jan 2010
- texas
silver- 2000 formula
the clean up begins.....I used simple green and wax grease remover.....simple green hardly put a dent in the messLast edited by sjsingle1; 10-03-2010 at 09:33 PM.
10-03-2010, 09:03 PM #22
- Jan 2010
- texas
cutting begins......the plastic bag helped.........but still a few shavings got in the valley.........used a dremel with those quickchange cut off wheels.......made the 1st cut at the bottom......then cuts in the middle......a big hammer will break off the pieces so you dont have to cut all the way.......i used a air grinder to finish upLast edited by sjsingle1; 10-05-2010 at 08:59 AM.
10-03-2010, 09:04 PM #23
- Jan 2010
- texas
just as according to LS1howto.......take the cut down to the bottom of the recess......I cleaned up the valley .....looked waaaay worse before full of hardened oilLast edited by sjsingle1; 10-04-2010 at 07:15 AM.
10-03-2010, 09:09 PM #24
- Jan 2010
- texas
LS6 steam tube.......the new style does NOT use LS1 gaskets under the blocksLast edited by sjsingle1; 10-04-2010 at 03:24 PM.
10-03-2010, 09:09 PM #25
- Jan 2010
- texas
put another LS6 steam tube in the rear......no block offs.....new OPSU...........dealer.......80$
10-03-2010, 09:11 PM #26
- Jan 2010
- texas
you cant see it.....but using the LS6 steam tube in the rear reverses the outlet....I cut the outlet off to about 1/2 inch and soldered it shut....the outlet hit the main wire harness before I cut it....smack dab in the middle of itLast edited by sjsingle1; 10-03-2010 at 11:11 PM.
10-03-2010, 09:12 PM #27
- Jan 2010
- texas
10-03-2010, 09:12 PM #28
- Jan 2010
- texas
button head bolts.....1 day I might get a FAST 102........got them off ebay......cheap........ace hardware charges out the ass for stainless metric boltsLast edited by sjsingle1; 10-05-2010 at 09:01 AM.
10-03-2010, 09:12 PM #29
- Jan 2010
- texas
10-03-2010, 09:19 PM #30
- Jan 2010
- texas
what LS1howto did not tell you........the wells for the knock sensors get filled with water...I had 1/2 of water in mine......leaving you this......add 2 KS to the parts list before hand........lucky for me autozone had some in stockLast edited by sjsingle1; 10-05-2010 at 09:02 AM.
10-03-2010, 09:20 PM #31
- Jan 2010
- texas
10-03-2010, 09:21 PM #32
- Jan 2010
- texas
new KS.......if I had to do it again......I would get a new KS wiring harness too
10-03-2010, 09:24 PM #33
- Jan 2010
- texas
when I put the KS wiring harness back on I use some permatex non harding sealer on the plastic caps to keep water outLast edited by sjsingle1; 10-03-2010 at 09:35 PM.
10-03-2010, 09:25 PM #34
- Jan 2010
- texas
look ma......no PCV.......i forget the PN for the rubber hose.....but it was only 3$ at the dealer
10-03-2010, 09:25 PM #35
- Jan 2010
- texas
steam tube button head bolts......M6 X 1 x 30mmLast edited by sjsingle1; 10-04-2010 at 07:11 AM.
10-03-2010, 09:26 PM #36
- Jan 2010
- texas
all done.......2 days......and BTW new intake gaskets are a MUST.....the old rubber 1s were shrunk and shriveled......LS1howto did not tell ya that eitherLast edited by sjsingle1; 10-04-2010 at 07:29 AM.
10-03-2010, 09:27 PM #37
- Jan 2010
- texas
the pics dont show how the idle has turned into a kittens purr with no vacum leaks
10-04-2010, 03:36 AM #38
10-04-2010, 07:09 AM #39
- Jan 2010
- texas
^^^^ your stayin after class for not reading the assignment and just looking at the pretty pictures
10-04-2010, 07:19 AM #40
Damn fine job and just how clean can an engine get these days???
LS2 Valley Cover
By PitchBlackLS2 in forum LS2/LS3/LS4/LSxReplies: 0Last Post: 11-28-2016, 06:49 AM -
Question: ls6 valley cover
By tangkiller_z28 in forum General HelpReplies: 7Last Post: 07-13-2011, 12:05 PM -
Valley cover
By sutie in forum Firebird / WS6Replies: 5Last Post: 02-24-2011, 05:07 AM -
LS6 Valley Cover and Catch Can
By ls1camino in forum External EngineReplies: 11Last Post: 05-20-2009, 08:23 AM -
LS! Valley Cover
By parbreak in forum Parts For Sale / TradeReplies: 0Last Post: 04-22-2006, 06:26 PM
