Results 21 to 40 of 168
06-14-2010, 04:29 PM #21
Depends on the Blower (IE KB, Eaton, etc...) and displacement of the blower. I've seen as big as 3.4Liter blowers, thats as big as a honda motor I would guess prolly around 8XX hp or so. Skys the limit with all cars if you have the cash. Go to SVTPerformance forums and ask, someones had to do it
┌∩┐(◕_◕)┌∩┐
wouldn't want to fight them!
06-14-2010, 04:32 PM #22
06-14-2010, 04:39 PM #23
^ Should I take that as good or bad? I know alot of Cobra owners swap Turbos on them to make gobs of power Its like any car, you gotta pay to play Just nice to come FI from factory.
06-14-2010, 04:42 PM #24
Figured you posted that after seeing my post in this thread about my friend running a Whipple 3.4L on his Marauder. I've seen it first hand, and helped him push the car from the 60' mark off the track when he snapped the 31 spline Moser axle in half...twice!
06-14-2010, 05:06 PM #25
06-14-2010, 06:31 PM #26
I was just using a estimate on a normal build. Obviously you could get into the thousands if you went all out on everything just like a LSX.
06-14-2010, 07:17 PM #27
Friend of mine had 2 of them, and without much effort at all they were both over 600 rwhp. Didn't even have to get inside the motor, no heads, no cams, very little money.
I can't remember the exact number it made but I know the car eventually dipped into the 10's on a drag radial and launching easy, crappy 60 foot times but it would run a stupid mph for a street driven car. I know it was well over 130 mph, but I just can't remember exactly.
We used to run head to head in my chevelle, and at the time he was running in the low 120's for mph and running low 11's. I was running low 11's but at 118 mph. We'd go heads up and I'd 60 foot him horribly, and he would have to chase me all the way down. The win light went in either way.
But all he had to do was crank the boost up, and a few more tricks later I couldn't touch it. Power adder cars are tough to beat.
06-14-2010, 09:09 PM #28
Only thing I don't agree on sir, its going to take a lot of money to make 600hp. I was looking into buying one that had the following:
Eaton S/C
Stage 2 cams
Steeda intake
Pulleys
Headers
Full exhaust
Tune
and a bunch of little shit and it made 6XXhp. That takes some serious cash for "Most"
06-15-2010, 02:24 AM #29
06-15-2010, 03:52 AM #30
06-15-2010, 05:30 AM #31
If you want to play....you have to pay.
06-15-2010, 05:51 AM #32
- Jan 2007
- Knoxville, TN
B2300 (Fluffy) Retired- Plain-Jane Dodge Truck
Hmmmm.....
An Eaton S/C comes stock on a Terminator. However, I don't know of any Eaton-equipped cars that make 600+ RWHP.
Cams are totally unnecessary in these cars to make stupid power. Waste of money and rare for a Terminator to actually have them.
There is no "Steeda Intake" for a blower car. Perhaps you meant Cold Air Intake (CAI)?
Pulley'd Eatons don't make 600+ RWHP.
Headers help a lot. However, they are typically considered part of a "full exhaust", such as what you have listed below headers.
Tune is absolutely necessary.
Anyway.....600+ RWHP on pump gas is obtainable with a KB or Whipple blower, exhaust, and a tune. A decent turbo setup would of course also do the trick, but is generally more expensive and complex. A KB or Whipple is essentially a bolt-on.
06-15-2010, 05:58 AM #33
Naaa, to take a factory car and make more than 600 rwhp for very little cash outlay is nothing when you compare it to starting from scratch. You mentioned a camshaft swap, and that kind of power from a termi doesn't need a camshaft swap to get to those numbers, like I mentioned my buddy never got inside his motor, so there is a big price descrepancy there.
Spending $2-3,000 or more on a car for HP is chump change. It costs more than that just to build a motor without a power adder. I think most of the younger crowds idea of tossing money at a car is several hundered bucks, but lets face it,,,,that doesn't get you very far with much of anything these days. Just to help put things into perspective here is an example of both of our cars.
My chevelle has a $9,000 motor in it, (and I assembled it) and it's still naturally aspirated. A $1,000 converter, in a trans that I also built, and I have more than $1,500 sunk in the rearend (that I also assembled)
So in a nutshell,,,,that's all just parts costs. All the labor is me. In my 4,108 lbs. car it's netted me bottom 11's at close to 120 mph, and makes 640 HP dyno'd at the flywheel. That's just the basic stuff, I won't even get into the money I spent on other things to make it all work, and I've far surpassed what you can spend on a termi and make even more power.
Like I said, he never had to get inside the motor to make that power, he has simply bolted on parts and tuned it to make more HP than I have,,,,and yet has spent less than half of what I sunk into mine.
Power adder cars make it look so easy it makes you sick.
To get a naturally aspirated LS1 to make those numbers would be difficult if not impossible, and you would spend 3 times the money doing it. That's the point I was trying to get accross.
06-15-2010, 06:04 AM #34
Expensive is a relative term. Everyones idea of expensive is completely different. And with most people on here wanting to do things on the cheap, I can see where $2-3,000 is excessive for most, but to be honest, even that amount of money won't get you far if you want to get serious about HP and do it right.
Exactly, this hobby is expensive, there is no way around it. Spending a few hundred here and there doesn't do much in this hobby.
06-15-2010, 06:09 AM #35
Exactly right. Bolt on a Whipple or KB, some other minor things with a tune and you're in business.
It's not that much cash outlay for the power level you accomplish. Like I said, these power adder cars make it look easy. Try that with the 14.7 atmosphere god gave us and you will spend some serious coin. Much more than you'll spend modding a termi.
I think that's what these guys are having a hard time grasping.
06-15-2010, 06:18 AM #36
- Mar 2010
- melbourne florida
navy blue metallic- 2002 camaro ss
2002 Camaro SS/M6. Volant CAI, 80mm TB w/spacer, cat delete w/ ory, borla XR-1 w/ cme, custom tune, 3.73's, 8,000k HID headlights and foglights, 19" staggered ruff 278 wheels.
06-15-2010, 06:23 AM #37
06-15-2010, 06:23 AM #38
- Jan 2009
- Delaware
Torch Red- 2003 Ford Mustang Mach 1
2003 Torch Red Ford Mustang Mach 1 5-speed
FRPP Aluminator 32V Long Block + Kenne Bell 2.1
657 RWHP 635 RWTQ @16psi on 93 Octane
Custom Tuning by Tillman Speed
06-15-2010, 08:43 AM #39
I wish it were that easy. Even a stock LS1 is only safe on about 8 lbs. That will only get you about 450 rwhp, nothing close to what a termi is capable of, even without a blower swap.
For an LS1 to be competetive, it would require a complete build, forged internals, good cylinder heads, custom camshaft, then comes transmission upgrades, a rearend swap. You will be into it for $10-15K or more to do it right and make the kind of power a termi makes with just a simple blower swap and a tune.
When you look at it from that perspective, the price of termi's along with a few upgrades don't look all that bad. You get what you pay for.
Very true indeed.
06-15-2010, 09:41 AM #40
terminators...
By freaky57fast in forum Kill StoriesReplies: 48Last Post: 06-11-2014, 01:20 PM -
Terminators (Our Doom)
By blackSS01 in forum Almost Anything GoesReplies: 5Last Post: 02-08-2011, 02:44 AM -
questions about ws6, vipers and terminators
By Murder after Midnight in forum Almost Anything GoesReplies: 93Last Post: 12-11-2007, 07:41 PM -
Terminators...
By waite87 in forum Domestics and ForeignsReplies: 12Last Post: 06-21-2007, 02:33 PM -
5 terminators, a s/c mach, VIDEO
By oneBADDz in forum Kill StoriesReplies: 20Last Post: 08-09-2006, 08:47 AM
