Results 21 to 40 of 45
Thread: Wierd noise and vibration??
02-19-2012, 09:39 AM #21
Ooope.. Never mind that bushing is a mount. Nevermind. Lol.
02-19-2012, 10:40 AM #22
Whole mount needs replaced
02-19-2012, 06:14 PM #23
Torque arm mount looks fine to me. I was simply letting you know what usually happens when they go bad. I agree with Kyle -- the trans mount looks a little iffy. How about your u-joints?
02-19-2012, 07:34 PM #24
Damm this part is around $70. I dont even have knoledge to replcae it
02-20-2012, 03:21 AM #25
What part... the transmission mount? If so, you should be able to buy one for for less than that and it takes all of 15 minutes to change it out.
02-20-2012, 11:51 AM #26
Yeah on autozone the mount was like $50 givr or take. But I will be sure to replace this part myself if I can figure it out..dont look too complicated
02-20-2012, 12:29 PM #27
$42.59 out the door here in Ohio at Advance Auto Parts
02-25-2012, 07:27 PM #28
Alright guys I have bout my trans mount and I will be working on it all day 2moro. I will update all of you for the goodnews about the noise gone. Xfingers!
02-26-2012, 02:15 PM #29
okay guys, my transmission mount has been replaced by pepboys.... I am quite confused. The vibration is loud as hell when you rev it to 2000 RPMS in park. Its like they didnt tighten it enough. Its scary loud. I didnt notice it till i got on to the car hard and it also vibrated. Im taking it back to them 2moro hoping they will find what is going on...
Any ideas what is wrong?Last edited by flybird; 02-26-2012 at 02:21 PM.
02-26-2012, 02:22 PM #30
man you might want to pull the transmission inspection cover and look up in there at your converter/flywheel! it shouldnt make any kind of vibration or noise in park if it were drive-train related?
02-26-2012, 02:31 PM #31
The mount def needed to be replaced. Before it was hitting the floor and creating all kind of noise, now its just loud ass vibration shaking the entire car..
Fly wheel/convertor? Were talkin big $$ here..
02-26-2012, 03:06 PM #32
K its not the flywheel, just had my nxt door neighboor mechanic check it out, it aint it.
They must have bolted it on wrong or something.
02-26-2012, 03:19 PM #33
even if they did, i still cant imagin that it would be noticeable in "Park" but i guess anything can happen?
02-26-2012, 03:30 PM #34
I know what your saying and I understand. But it NEVER did this until they put on the new mount. I shakes the entire car like never before. There must be an untighten bolt. Idk.
02-26-2012, 04:49 PM #35
By chance, did they replace it with a polyurethane mount in lieu of a stock rubber mount?
02-26-2012, 05:01 PM #36
No no its not the poly, I bought this mount, I got an oem rubber.
I knew this ? might come up should have told yall in the begining.
02-26-2012, 05:06 PM #37
I bought a $40 mount, which is the rubber oem.
There was a $75 mount which I do belive its the poly.
02-27-2012, 01:33 PM #38
@ MY00Z28
You were right man, I hate how you are right I really do.. But you are. The flywheel is either cracked or lost its balancers. Pepboys couldnt figure it out sadly.... They were scracthing there heads n simply said I dont know.. Called a few folks and evryone said its the flywheel man..
Oh god, my baby just likes all the attention and money... This is very aggrivating..
02-27-2012, 03:38 PM #39
I may be right, I may be wrong... But you wont know till you get her apart....
02-27-2012, 03:56 PM #40
ill be finding out this saturday. already ordered the flywheel bc i dont want to take it apart then not having a flywheel and end up having to wait for it to be shipped... but majority of the ppl(which are mechanics) said it must be the flywheel.
Ill tell you on saturday, deal?
Wierd vibration in Drive...
By StuntmanMike in forum Automatic TransmissionReplies: 20Last Post: 10-16-2010, 08:10 PM -
Question: wierd noise/vibration/clutch chatter?
By T-Rexxx in forum Firebird / WS6Replies: 4Last Post: 02-11-2010, 07:27 PM -
Wierd vibration...
By StuntmanMike in forum Automatic TransmissionReplies: 1Last Post: 12-15-2008, 07:45 AM -
Wierd vibration not the drive shaft maybe?
By grandkodiak in forum LT1Replies: 15Last Post: 06-21-2007, 07:19 PM -
wierd vibration...
By mity2 in forum LT1Replies: 3Last Post: 03-01-2006, 08:11 PM
