Results 21 to 32 of 32
Thread: '87 Monte SS LS2/4L60e2 swap
01-24-2015, 04:37 AM #21
Sorry, not sure on that one. I'll see if I can find out.
01-24-2015, 04:44 AM #22
If the LS2 sensor is on each side of the block, it appears that you have to drill the holes out to 8.5 mm and then tap them with an M10 x 1.5 tap for the LS1 style knock sensor to work.
01-24-2015, 07:52 AM #23
- Dec 2014
- El Paso, Tx
White- 1987 Monte Carlo SS
Thank you for the info. That is not going to be fun now that the engine is in the car!
01-24-2015, 08:52 AM #24
There may be other options. I am uncertain the difference between the two sensors... other than size. Could be something you can adjust for in the tune.
01-25-2015, 06:55 PM #25
- Dec 2014
- El Paso, Tx
I read where you can thread the LS1 knock sensors in to one of the motor mount bosses, since I have the 1" setback adapter plates. What I'd like to know is if the sensor will work as it should since the material around that area is rather beefy.
01-26-2015, 12:24 PM #26
I did see that as well -- you can adjust their sensitivity within the tuning software.
01-26-2015, 12:26 PM #27
Pssh, turn em off and just tune off of AFR...nothing can go wrong there ;-)
01-26-2015, 12:35 PM #28
Until the fuel pressure drops and you burn a piston...
01-26-2015, 12:43 PM #29
Indeed, I was joking
01-26-2015, 12:55 PM #30
I assumed as much, but when you have others reading these threads I have to make sure that they don't interpret what we know as a joke to be the gospel truth.
01-26-2015, 08:12 PM #31
- Dec 2014
- El Paso, Tx
Amen!
02-03-2015, 06:45 PM #32
1980 Chevrolet Monte Carlo - Mighty Monte
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 07-20-2010, 04:00 AM -
the monte
By cuervo25_1 in forum Member's RidesReplies: 1Last Post: 06-23-2009, 04:59 AM -
5.3L swap 86' monte carlo
By redlinekink99@aol.co in forum Classic MuscleReplies: 1Last Post: 02-25-2008, 10:12 PM -
Swap a gen 3 ls into a Monte Carlo?'s
By FORMULA7 in forum Texas MembersReplies: 3Last Post: 02-12-2007, 02:46 PM -
88 monte ss
By 1fastcamarosss11 in forum Vehicles For Sale / TradeReplies: 0Last Post: 01-01-2006, 06:15 PM
