Results 21 to 32 of 32
Thread: Differential Fluid change
04-10-2008, 07:59 PM #21
04-10-2008, 08:00 PM #22
As far as the gasket though, you don't have to worry about the cost-they only are about $3.50 or so!
04-10-2008, 08:03 PM #23
Alright thanks a lot for ur help this makes things so much easier for me. Within the next 2 weeks Im plannin on doin this.Id like to get the Royal Purple from u. So ill send a PM in the next couple days. Once again Thanks!
04-10-2008, 08:05 PM #24
Here's a list of stuff I recommend for changing your differential:
1.) 2 quarts of Royal Purple 75w-90
2.) 10 Bolt rear differential cover gasket (mentioned earlier)
3.) High Temperature RTV silicone
4.) Brake/Carb Cleaner
5.) A razor blade
6.) 1/2" wrench & 3/8" socket wrench
7.) A drain container (anything to put the old oil into) and plenty of rags
04-10-2008, 08:09 PM #25
04-10-2008, 08:10 PM #26
04-11-2008, 06:48 AM #27
I Never use a gasket and haven't had any leaks on many,many,many rearend covers. A can of brake clean and a small bead of Ultra Black let it sit for 10-15 min. and bolt up.
I think the Amsoil and the RedLine are a far superior fluid then the RP myself due to tests.Don't be afraid of the bottle!!! Be afraid of your tune!!!
04-11-2008, 07:40 AM #28
So, in a sense, you do use a gasket if you're using a liquid version to seal it What tests are you talking about? I'm not trying to come off as being an ass, but I like to stay as objective as possible & if tests have been done proving superiority with a different brand I'd like to check it out!
04-11-2008, 08:53 AM #29
04-11-2008, 10:52 AM #30
It was done by one of the big circle track magazines with a a couple different cars. One was a 700hp sprint car and the other was a 450hp modified.
They had a temp gauge sensor probe welded to the housing and did a temp. comparison and a analysis of the oil after 200 laps.
I probably still have it some where. I'll try to look this weekend. Shit there is probably 200+ magazines laying around the shop. LOL
04-11-2008, 02:36 PM #31
http://www.bfranker.badz28.com/fbody/lubeoil.htm
I found that website and followed all the directions and it ended up being very easy! the only thing i didnt do was the GM additive which im thinking of putting in later anyway just in case. The only reason i didnt use royal purple was cause i couldnt find it. Of course after i was done with diff lube change i found it in PepBoys!
Thanks for the help to everyone who wrote back to me on this!!!
04-04-2011, 12:11 AM #32
- Mar 2009
- Arizona
Red- 2002 SS Camaro
Does it have to be 75-90 or can i use 80-90 cause thats what i just bought lol
torquer v2 cam, LT headers, maf, 3inch true dules, X pipe, 420hp 385tq
Help: Trans and differential fluid
By 98maro in forum General HelpReplies: 20Last Post: 03-29-2010, 05:50 PM -
Question: Differential fluid
By mdcrabbie in forum DrivetrainReplies: 2Last Post: 02-27-2009, 06:46 PM -
Rear differential fluid change
By Z28LS1 in forum DrivetrainReplies: 8Last Post: 03-15-2008, 06:42 AM -
Differential Fluid?
By shlby123 in forum General HelpReplies: 12Last Post: 03-13-2007, 11:19 PM -
By thirdbird in forum DrivetrainReplies: 3Last Post: 04-12-2006, 02:55 PM
