Results 1 to 15 of 15
    Dec 2009
    Missouri
    1996 Camaro
    Radio and Power windows issues
    I have a 96 and I need to know where the relay is that keeps the radio and windows working until you open the doors. I am having problems with my radio and windows not working randomly, I can hit the radio most of the time and it will come back on yet to go back out again. I want to disable and bypass that relay so I can rid myself of that headache.
    Thanks
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by T/A Addict View Post
    Thanks
    Prolly not any relay. Is probably the BCM (Body Control Module). It located under the passenger side of the dash. It's a very common problem with our cars.. The module is known for having bad solder joints on the board..
    Pittsburgh
    2008 Hummer H3
    It's a small black box and inside it will have the BCM board these are the problem areas of the board..
    Pittsburgh
    2008 Hummer H3
    Oh yeah and welcome to LS1.COM...
    Dec 2009
    Missouri
    1996 Camaro
    Thanks, Is this an easy item to remove?
    Pittsburgh
    2008 Hummer H3
    Not too hard @ all.
    Remove the kick panel under the passenger side of the dash. Then get under and look up behind the back of the glove box. There will be a couple plugs that will need to be pulled out of the module. Then carefully pry back the clip/housing that holds it into place and slide it strait down. To replace just push it back up into place till it clicks, then plug it back in and you're done.. Good luck.
    Pittsburgh
    2008 Hummer H3
    Oh yeah the board can be removed from the box easily if I remember correctly from doing mine, the box just snaps shut with clips that are molded into the box it may have a couple screws though not hard..
    Lincoln, CA
    2000 Z28 Camaro
    Do you recommend replacing the board or trying to resloder the joints that you've outlined? Any idea how much a replacement part costs? I'm betting you have to buy a complete BCM from Chevy.
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Quote Originally Posted by RagTop View Post
    yes you would have to buy a replacement and they are not cheap at all. just take it out and try this first. It may save you 300+ bucks.
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Oh yea, another thing to check is the door switches. sometimes they go bad and if the BCM thinks the door is open then it wont stay on.
    Pittsburgh
    2008 Hummer H3
    I would attempt the easy solder way first if money is tight for ya.. If not just replace it..Plug and play..
    Quote Originally Posted by JaycenK View Post
    agree with this too
    silicone spray and work the switches rappidly with your thumb after.
    Tulsa,OK
    Quick Silver
    2002 Z06
    Not too hard to get at... You can find instructions on getting that kick panel off by reading the first steps to our Passenger window fix install instructions...
    Link in my sig.
    Camaro Owners Click Here
    Firebird Owners Click Here
    www.AutoTrix.net
    Dec 2009
    Missouri
    1996 Camaro
    The one thing about the door switch being the issue is that the radio and windows should still operate when the key is on even if the door is open. Correct me if I am wrong.
    Dec 2009
    Missouri
    1996 Camaro
    Thanks for all the info Smittro, I repaired mine this weekend. Took me only about 20 minutes total and although I have very limited experience with soldering it seems to have worked, no issues so far.
    Apr 2014
    Pensacola FL
    Trying to see the pics u posted of the BCM but not working. An u post them again
  1. Help: Radio and power windows stop working at same time
    By sc5309 in forum General Help
    Last Post: 08-17-2014, 05:11 PM
  2. Shut off for radio and power windows
    By bberretta in forum Stereo and Electronics
    Last Post: 09-17-2013, 08:58 AM
  3. Windows go dead, radio cuts off....!
    By IronBird in forum General Help
    Last Post: 01-26-2008, 09:42 PM
  4. Power windows and radio stop working once in a while
    By 1980millwright in forum Stereo and Electronics
    Last Post: 09-23-2007, 08:06 PM
  5. Problem with Power windows and Radio at same time
    By TimC in forum Stereo and Electronics
    Last Post: 06-05-2006, 08:13 AM
