1 Attachment(s)
can AWD SUV have wet tire on rear dry on front
I’ve never owned a AWD all wheel drive vehicle but seam to remember that these vehicles require all tires to be the same is this true or false.
Main purpose for this 97x same as trailblazer is towing a 2500LB vessel 200 miles and out of sometimes slippery/steep boat ramps so the nitto performance tires won’t do for rears.
Can I get away w/ performance nitto on front https://www.discounttiredirect.com/b...SABEgKmRPD_BwE
Or https://www.discounttiredirect.com/f...at=nitto-tires
and wet nitto on rear https://www.amazon.com/NITTO-TERRA-G..._&dpSrc=detail
A friend warned me to not do donuts the AWD SUV has tendancy to flip itself
is this true or false?
Thanks
I'm not sure how the AWD system is set up on a trailblazer/97x, but some systems will frag themselves over time if there's even a variance in overall diameter as little as 1/4". that said, always play it safe and replace all four at the same time and be diligent about doing regular tire rotations and keep the wheel alignment in check to prevent premature wear on any particular tire(s).
